What is a low NFB design? And what about the longevity of tube preamps?
NFB is a common abbreviation for Negative Feed Back, used in amplifiers:What is a low NFB design?
I have the cfa3 as well with both the sr1a and the ca-1a and I would be very concerned about connecting them without the adapter but if others try it and say it works I will think about itWait, what? Seriously?! Now I'm embarrassed. I own a CFA3 and had no idea. But if I am going to be embarrassed, I'm glad it's with great news. Excited to try this out . . .
It works but doesn’t sound good. You can try for the sake of trying, but definitely not the way to go.I have the cfa3 as well with both the sr1a and the ca-1a and I would be very concerned about connecting them without the adapter but if others try it and say it works I will think about it
That's the idea behind the TI vs RI!I've tried the standard interface box (RI-1a) with the CFA3 and have had no problems doing so... but... Might the new TI-1a be the better solution for the low powered (vs speaker amp) CFA3?
Stay updated on RAAL 1995 at their sponsor profile on Head-Fi.
On the subject of cables, how far are you from offering the upgraded cables? I remember you mentioned in one of the posts that you are preparing to launch some new headphone cables for the TI box.That's the idea behind the TI vs RI!
With TI, there will be about 6-7dB more of max SPL on headphones. And the current draw from the amp will be far lower for the same SPL.
However, to get that, you can't use the old "standard" cable that was coming with the RI.
That's why now the headphone cable belongs with the TI set, not with the headphones. We need to correctly load those transformers to get the expected result, as well as 32/16 Ohms at their input.
I'm happy to say that we are done with testing and trials, and couldn't be happier with the result!On the subject of cables, how far are you from offering the upgraded cables? I remember you mentioned in one of the posts that you are preparing to launch some new headphone cables for the TI box.
Sounds like a winner! Will there be other cables planned in the pipeline or Star-8 is the only one?I'm happy to say that we are done with testing and trials, and couldn't be happier with the result!
Figured out the annealing cycles, got the braided jackets designed and made, just waiting for the printed sleeves, then make some and ship them to Danny!
He will have a few delivered on Monday the 26th. Sep.
BTW, Danny had a pair of production prototypes playing at CanJam. They looked like this, but with printed markings:
The specs of Star-8 Pure Silver are:
6ft in length
~0.23 Ohms (loop resistance), same like SC2, so no extra power needed in comparison.
~0.37uH at 6ft.
We got increased resolution, but without harshness, with increased bandwidth of the TI-cable-headphones chain.
I have to say that Danny and I have never heard the SR1, CA1 and TI sounding like this before. There is so much happening in the music, but without imposing itself on you. We are enjoying the discovery that our headphones are much better than we thought![]()
so can I assume this cable will provide the juice needed to drive through the TL box because some do notI'm happy to say that we are done with testing and trials, and couldn't be happier with the result!
6ft in length
~0.37uH at 6ft.
Well, we are somewhat biased, naturally, but it's really a winner. We've learned along the years how to remove the bias as much as possible.Sounds like a winner! Will there be other cables planned in the pipeline or Star-8 is the only one?
As for that, it is the same as SC2 (the headphone cable that comes with the TI), so no change in that department.so can I assume this cable will provide the juice needed to drive through the TL box because some do not
