Being in the same boat, having my SR1a with the original amp interface for several days of intensive listening now:
My impressions are quite similar.
The major first step is experimenting with the various degrees of freedom in head placement.
The short video from the Raal website is sure worth a look in this regard:
I would not call myself a bass-head, but do like solid base and fundamentals in my music.
At the same time I’m generally not listening very loud, vocals in the music are a bit louder than normal humans talking.
Typical music level ca. 65-70 dBA Leq (long term average), with peaks up to 95 - 100 dB SPL.
The power amp is not challenged much: ca. +20 dBu or 10 W / 6 Ohm Peak typically is the very highest I observe.
I love music with lot’s of dynamic, try to avoid contemporary, dynamically over-squashed remasters.
First based on measurements (on my own head, mic inside my ears), then hours of fine-tuning I made an EQ setting that adresses all mentioned Issues, without overdoing it or killing SR1a’s character.
Specially the bass becomes viceral in a way I did not expect from SR1a.
The EQ slighty addresses midrange and treble too, this is very personal I guess.
Doing more in the mid/treble range sounds too much for me.
Treble is better controlled by positional variations, than excessive EQ.
With the EQ the bass and fundamentals sound punchy, compact and present in a way I did not expect from SR1a.
The fastness stays, combined with a significant gripe on the related instruments.
No hint of tizzy or thin sounding any more.
Positioning, probably quite personal, but another person found similar settings favorable too.
• Driver flaps angle: L 27 ° R 27 ° few millimeters away from pinnae contact. I made little card-box angle stencils to set this up.
• Driver horizontal position: usually ca. 5 mm to the front from the back-most possible position, very tiny bit more forward than the upper-mid-hottest position. I do use this to regulate the treble amount.
• Driver height: center driver ca. aligned with ear-canal entrance.
• Wearing angle (seen from the side): upper part, headband, slightly backwards, ca. 10 °.
• Fit: tight fit, still comfortable, don’t need the back-strap.
Raal SR-1a EQ04
RME ADI-2 Pro.
THE EQ DOES NOT CONTAIN BAFFLE COMPENSATION as the standard SR1a amp interface already has it.
There are EQ bands left to do this, in case needed.
Gain / Freq / Q / Type / (comment)
.. dB / Hz
+5.5 / 130 / 0.8 / Shelf / (adjust gain to taste)
n.a. / 25 / 1.8 / High Pass / (High Q boost the lows SR1a is capable, removes below)
-2.0 / 2.1k / 1.5 / Peak / (vocal presence)
-1.5 / 6.3k / 3.5 / Peak / (harshness)
-2.5 / 9.1k / 5.0 / Peak / (Sibilants)
