After reading the information right here, if I didn't get it wrong, the Sr1a/b with TI-1a/b needs the OB Compensation to plug on the amp side before your rca/xlr cable plugged, is that correct?
Correct.
If yes, if I use normal headphones, I need to unplug the OB Compensation barrel to listen to those..
Not necessarily...
Do you think it is a bit messy to change the plug every time if I want to switch the headphones? I saw someone built a switch on the speaker interface, but is it possible to build the OB Compensation barrel inside the TI-1a?
It was possible, but...all passive filters need to work with an exact and known load impedance.
In this case, that would be the impedance on the primary of the transformer, say 16 or 32 Ohms, so no problem there, until you try any other headphone cable but the one that comes in the set with the TI, as the change in the cable resistance at the secondary of transformer, will also change the primary impedance, so the filter will change the frequency and attenuation ratio.
Basically, it would be some other curve than desired.
Also, such filter would require large inductors, so for all those reasons it was never considered as an option, versus the elegance of a RC filtering at line-signal-level in a barrel adapter.
My RCA cable is a bit too clumsy to unplug and plug again just for adding the barrels on it, may I know anyone has this situation?
Also, I would like to know if anyone is using TI-1a with AIC10? Do you think the bass quantity is enough? I have tried with the speaker interface in the past with AIC10, but the sound is not satisfied.
The idea was never to plug and unplug anything.
All amps and all DACs have at least two inputs and outputs, so use both at the same time.
Choose, for example, XLR input of the amp for the OB compensation, use an XLR cable from the DAC XLR output to that.
Use the other input (RCA) for regular connection from the RCA output of the DAC.
So, by switching the input selector, you are switching the SR1 OB compensation on or off.
