jlbrach
- Jun 4, 2005
if anyone out there has heard both the 1b and the new tube amp I would appreciate a comparison and a subjective reason to buy the tube version or upgrade from the 1b?...thanks
Compared to the HSA-1b, the VM-1a seems to sound a bit clearer to me. It also is sounds incredibly powerful in Pentode mode. I had some expensive preamp and amp combos that I liked more than the HSA-1b, the very best being the KRELL Duo 175XD + CODA 07x preamp (about $16K combined). I liked this combo more than the HSA-1b. However, I liked the VM-1a much more than the CODA + KRELL combo. I subjectively said about 25% better, which is a lot.if anyone out there has heard both the 1b and the new tube amp I would appreciate a comparison and a subjective reason to buy the tube version or upgrade from the 1b?...thanks
Compared to the HSA-1b, the VM-1a seems to sound a bit clearer to me. It also is sounds incredibly powerful in Pentode mode.Compared to the HSA-1b, the VM-1a seems to sound a bit clearer to me. It also is sounds incredibly powerful in Pentode mode. I had some expensive preamp and amp combos that I liked more than the HSA-1b, the very best being the KRELL Duo 175XD + CODA 07x preamp (about $16K combined). I liked this combo more than the HSA-1b. However, I liked the VM-1a much more than the CODA + KRELL combo. I subjectively said about 25% better, which is a lot.
I also had a CODA #8 amp which I used with the CODA 07x preamp for the SR1a. I was reluctant to sell the #8, since it was so good. However, I needed the money to buy the VM-1a. The VM-1a was so much better. After hearing the VM-1a I figured no 2-channel amp could surpass it since the 2-channel has to go through the resister box.
There were 2-channel amp combos that I liked over the HS1-1b, such as, CODA 07x +CODA #8 and CODA 07x + KRELL Dou 175XD. A few other 2-channel combos I tried were not as good as the HSA-1b, such as, Benchmark AHB2, Benchmark LA4 preamp, LSA Voyager 350 GAN, Parasound A21+, and D-Sonic Class D stereo amp, and Schitt Freya+ premp.
I currently have the VM-1a and the Schitt JR in different rooms. I use both but I am thinking I should get the HSA-1b to replace the JR. The JR is not as good as the HSA-1b.
Could be dependent on age and hearing acuity and other health related conditions. There's no stopping the aging process. I no longer hear much above 8K so any noise component above that frequency will be less audible to me.A quick follow-up...the RCA tubes are here, the hiss in pentode mode is the same as with the stock tubes. Otherwise it functions without problem. Cannot say too much about the change in sound quality, I used the stock tubes about 30 hours, now this. Either way it sounds really good and I am just too lazy too swap back and forth the tubes to analyse the differences.
Maybe I am too sensitive to hiss and this is normal?
I haven't gotten my VM-1a yet, my dealer is still awaiting delivery, they were expected 6/30.Hi @FLTWS in my quest for a replacement 6SN7 for the VM-1a i noticed you have a few these tubes, have you tried them on the VM-1a?
The Linlai and the Treasure Globe look intriguing.
The shortest distance is to the driver tubes from the middle to tube is 3.5 cm. With the Linlai being 5.6cm wide the distance between the two glas is 0.7 cm. For the TG being 58.5cm wide so between glas it’s 0.58 cm. According to the grant fidelity website 0.5 cm is max.Hi @FLTWS in my quest for a replacement 6SN7 for the VM-1a i noticed you have a few these tubes, have you tried them on the VM-1a?
If that 3.5cm is from the center of the driver tube (the 6sn7) to the glass of the front two EL-34's on either side, which are used to provide high current/voltage swing capability, then both tubes will fit physically, if a bit tight, and it becomes a matter of heat being thrown off by the driver tube (in this case the Linlai or Treasure Globe). While heat rises up there is still some throw off from the sides of the tubes. Whether or not this will have any affect on any of the tubes I have no idea. I may find out in time.The shortest distance is to the driver tubes from the middle to tube is 3.5 cm. With the Linlai being 5.6cm wide the distance between the two glas is 0.7 cm. For the TG being 58.5cm wide so between glas it’s 0.58 cm. According to the grant fidelity website 0.5 cm is max.
No, from the center of the 6sn7 it’s 3.5 cm to driving tubes glass and 4 cm to the output tubes Glass.It's difficult working from a photo and the manual I downloaded (assuming its to scale) indicates the the center of the 6SN7 is the same distance from the center of the 2, 3, 5, and 7 tube sockets.
Through a series of connections (loopout, preamp, splitter/isolation XLR box, etc.), my system accommodates three amplifiers all fed by only one DAC, one of them being the Schiit Jotunheim R, so compensation via digital eq was not a solution (but I don't use digital eq in general). So I risked buying the analog OB compensation barrels, which Raal sells together with its new interface, to avoid using the JotR's active compensation switch, which, according to my perception, is a merciless killer of the SR1a, and the result was VERY VERY good, maintaining the explosive dynamics and transparency of this aluminum divinity. For those who own the JotR and cannot yet "upgrade" to the new stuff that costs 7k, I emphatically suggest analog compensation, a wonderful solution.Does anyone compared with the digital filter and OB barrel? I am quite curious which will sound better.
