I couldn't help myself and already ordered the new TI-1a.
But to be clear, I would also like to hear from those who have been working on/tuning it what they'd have to say here!
Thank you!
The goal was to have the most transparent transformers. We've been developing the VM tube amp for two years and we definitely liked how Toroidal Output Transformers worked in it and I went on to develop the Toroidal ones for the TI. Eventually, I ditched all my Amorphous C-core prototypes as they were inferior.
By it's nature we've had low leakage inductance, extending the bandwidth, and the distortion was the same. Then the task was to reduce the leakage even further, to the lowest possible value. Given the high transformation ratio and very low secondary load, that was a complicated thing to do.
We're using high-permeability cores, so low-level detail comes out very nicely. The limit in that regard will be in the amp, not the TI or the source.
This high permeability with toroidal cores with no gap is a problem when there's a DC offset at the amp output, so the primary has a certain resistance that prevents core saturation.
In parallel to that, the cable problem had to be solved, as the cable is the dominant load to the TI secondary.
So, little by little, the best combo of parameters was found and I was able set the cable length and the transformer ratio for best results.
There is also the backwards compatibility with our "old" Silver cables, as they are having very low inductance, so they can work wonderfully with the TI.
there's no need to bother you wirh more details, as once you get your own, you will try it on different amps and see if it preserves what they can do or not. I hope you will be very happy with what you hear, but you'll be the judge.
