I see a set of SR007 there. How well does it drive those? I have found them hard to drive on Stax's own lesser amps.
In that configuration, pretty well - if it is setup right (see below). Better than any other energizer I've heard. And better than when feeding the Pro iESL via the Pro iCAN.
With the SR-007 MK2 in that setup you'd need to set the HSA-1b's input-level attenuation to 0 dB, run the Pro iESL on its 24 ohm (64x gain) setting, and then set the RME ADI-2 Pro FS R BE's output reference level to +13 dBu and connect via XLR. That puts the volume dial in the middle for my normal listening.
If you used a normal consumer-level output via RCA into the HSA-1b there, then getting sufficient volume would be an issue. With XLR you'd have more headroom, but quieter recordings (or those that haven't been loudness-squashed) could still mean you need to push towards the end of the volume range.
With the SR-009S, which I also have, you'd have more leeway, and could run a normal level output into the HSA-1b and still have headroom on the dial.
Both configurations will play cleanly, and louder than I care to listen, but again with the SR-007 MK2 that is predicated on balanced-input from the RME set at +13 dBU.
