Raal Ribbon Headphones - SRH1A
Dec 13, 2020 at 7:37 PM Post #3,136 of 7,885
Seen a lot of live music the last nine months?
This years a loss for obvious reasons, got a few in in Jan and Feb, donated back tickets for April and May. I expect to make up for it next season when it starts in Sept.
Dec 15, 2020 at 1:48 AM Post #3,139 of 7,885
I use a tube pre-amp (wa33). It definitely improves the sound and increases the bass a bit
Dec 15, 2020 at 5:04 AM Post #3,141 of 7,885
I need help connecting the CHORD HUGO2 to the Jotunheim R. I assume RCA out from H2 to JR in? Also what volume settings are best combination for the two? Plan to control overall volume with H2 remote but what volume should the JR be set to for best results??
Thanks
Dec 15, 2020 at 1:18 PM Post #3,142 of 7,885
Thanks
Yep...you got it. RCA outputs from the Chord, to the RCA inputs of the Jot R. As far as the volume knob goes, you can email Jason at Schiit and ask him where 'Unity Gain' is on the Jot R....and keep your knob there. In the absence of that info, I usually just take it to 100%, and would use the Chord for the variance. This doesn't work as well if you have other people using your rig though.....as you might imagine.
Dec 15, 2020 at 3:11 PM Post #3,144 of 7,885
Dec 16, 2020 at 4:56 AM Post #3,145 of 7,885
Just listened to the HD800S, coming from the SR1a after few weeks.
Well both are great, but HD800S feels like Headphone, while SR1a doesn't.
Can't describe it otherwise
Dec 16, 2020 at 5:09 AM Post #3,146 of 7,885
Thanks
Dec 20, 2020 at 5:56 PM Post #3,147 of 7,885
Hi guys,
I am seriously considering to add these headphones to my collection. My current plan is to use the interface box powered by my Prima Luna Dialogue Premium HP.
I am thinking on using Kimber 4TC between the amp and the box. What do you think?
Also, I know there have been mentioned different options for cables from the box to the headphones. In your opinion what is the best one?
Thanks.
https://www.facebook.com/MoonAudio/ https://twitter.com/MoonAudio https://instagram.com/moonaudio https://www.moon-audio.com/ https://www.youtube.com/@moon-audio sales@moon-audio.com
Dec 20, 2020 at 6:28 PM Post #3,148 of 7,885
great choice to add the sr1a...I am using the schiit jotr but I know there are several great amp options
Dec 20, 2020 at 7:36 PM Post #3,149 of 7,885
Hi guys,
Thanks.
I'm running Nordost Heimdall between my Bryston and the interface box. It was a noticeable improvement over the supplied cable. I'm sure the Kimber will work fine. When you get the headphones, try the stock cable for awhile....get the measure of them, then swap 'em out for the 4TC's. That should tell the tale.
