FLTWS
True.
Woo stand is very tall and well built.
I have not made decision between Freya, MJ2 and Rh5 yet.
Which is better to drive 1266 Phi between Mj2 and Rh5 from your experience?
Thanks a lot for your detailed answer.2 slightly different sounds to my ears; my MJ2 tends towards clinical truth, my RH-5 is more of a warmer / romantic sound.
But, complicating matters with both is tube selection which can accentuate or mitigate those qualities enough to alter what I think about the sound.
One size doesn't fit all and your choice of music may play into it as well.
What satisfies me may not satisfy you.
Personally, I like driving my 1266 with my Formula S / Powerman combination.
I'm tube versus SS versus hybrid agnostic. I've heard examples of all types that I like or don't like so...
I should also mention that I've been on as steady diet of SR1a since my Jot R arrived Jan 21. I've spent a little time with my Phi and Utopia and all I can say from my perspective listening to classical and acoustic Jazz genres, the SR1a is my sound preference. Transparency, coherence, speed, openness, and uniformity of frequency response still has me shaking my head and gives me a "that's what the instruments sound like when I go live" experience that really comes into sharp focus when I switch to another headphone. It may not be the best HP for all genres so there is room for other options that other listeners will prefer and find more satisfying. I've found the bass response is as much a function of recording quality as anything else. And a little 20Hz Loki takes care of any shortcomings in a given recording for my taste.
And I am looking forward to the release of the new version of the HSA-1 coming to be able to compare my other phones against the SR1a using the same amp. While it may not be the optimal driving engine for all types of HP loads it will help me be able to better compare them and maybe come to some final conclusions for myself. I'm also still fond of my HD800 (and 800S) but I have a custom OTL coming to be used with just that headphone that is just right for that model.
Sorry for the non-answer to your question but that's all part and parcel of the "audiophile" experience.
Definitely. I have a Woo stand for each of my headphones.Woo stand is very tall and well built.
My 2 channel system of Lansche 4.1
It is good to hear about your experience in having tube in front of Jot R.That plasma tweeter in Lansche speakers is one of my very favorite drivers (not just tweeters) I've ever listened to. Lucky man.
I have been enjoying the Jot R with iFi iTube2 tube buffer with Bendix 2C51 tube rolled in, skipping the interconnect with RCA-to-RCA adapter instead. This contraption minimizes the transparency loss to a very minimum amount while giving that lovely tube magic.
0410201542 by drjlo2, on Flickr
It was expensive at 55k$ on 2007.I remember a plasma speaker my brother and I auditioned at a dealers back in the 80's I believe. It was big, expensive, and dangerous as I remember it.
Pretty nice, where did you get those adapters?
A quick search online lead to a eBay seller from Hong Kong, but they were a little different from yours.
FatWyre is the The Cable Company according to their same address & phone#.I recommend you to use this cable lending service
https://fatwyre.com/
Choice of cable is dependent on personal taste and system matching.
Sr1a and Jot R sounds fast and open but close to hot.
If you contact them on the phone or e-mail, then they will recommend you to try out up to three different cables.
Then you may choose one among them after home audition.
Anyway, as of right now you can't borrow anything from them due to CV-19.
Thanks for the reference. What a range in price from $400- $3K plus. After much research of the reviews I decided to go with this one for $150: http://stagersound.com/silver/ until my SR1a is fully burned in and ready to take it to the next level.I recommend you to use this cable lending service
Thanks, that looks like the right choice. Appreciate the suggestion.True.
