Sucks the HSA-1a doesn't have a pre-in option like the Jot R does, so no tube preamp can be used with it.
What are you talking about?*
The HSA-1a has two analog inputs, just like the Jotunheim R, one single-ended (RCA) and one balanced (XLR). The Jotunheim R has an option for a DAC on top of that, but both of the units are primarily analog-in
There's no issue at all putting a tube-buffer or tube-pre-amp in front of it, just like you'd do with a Jotunheim R if that's what you wanted. As with ALL such arrangements, you just need to make sure your tube-pre/buffer has an output level that doesn't clip the inputs on the amplifier it is feeding.
*Unless you're being sarcastic and I missed it being pre-coffee.
