Leopold
- Feb 18, 2006
As I see it, there is much hype in the silent pc business. For instance, take all these "silent case fans" which are db-rated and everything. Then take a look at the air they are moving... I found that a large, high cfm cheap fan that is regulated down to 800 - 1000 rpm is just as silent and moves just as much air. Ok, this is no big deal since fans are relatively cheap anyway.
But take fanless PSUs. This sounds like a nice idea but you normally need fans to move hot air out of the case anyway. There are very good near-silent and relatively cheap PSUs that helps doing just that. Boosted by a large cheap fan like above the net result is excellent case cooling and extremely low noise levels. With a fanless PSU the case fan would have to work harder, increasing system noise in comparison.
And to what help is any of the above if you have a mainboard chipset fan that is the only thing you actually hear from the computer if you listen carefully. As mentioned, these are not easy to deal with, the only really recommendable thing is to choose a mainboard that has no chipset fan at all.
I'm not saying the aftermarket silent solutions are ineffective, just that a systems perspective is necessary from the ground up to get that silence we all want.
Originally Posted by Uncle Erik Take a look here: http://www.silenx.com They have terrific fanless PSUs, very quiet fans, hard drive coolers/quieters, and other stuff, too. |
