earnmyturns
1) Hi! What US dealers carry the QP1R?
2) Does the QP1R come with a case or do I need to buy that separately?
3) Does the QP1R have glitches or slight bugs to get used too?
4) What is the expected battery life playing all various bit rates of MP3?
5) Can one scroll through the menus and music without using the scroll wheel?
6) Does the QP1R work with Sandisk 256 gb micro sd cards?
Abbreviated above to what I know to answer.
1) Got mine from Moon Audio, happy with their speed in answering questions and fulfilling the order.
2) Buy separately.
3) None that's annoying enough for me to remember
4) I only listen to lossless FLAC. Longest use was around 7h on a transcontinental flight, battery ended at 40% or so.
5) Yes, with the buttons.
6) It works perfectly with the 200GB model, formatted as ExFAT, which was the max from SanDisk before the 256GB came out.
In terms of sound signature, I don't know any of the headphones or amps you referred to, but it's surprisingly balanced and full or detail for such a small device. I currently use it with Etymotic in-ear ER4Ps, but I have also Aeons on order to use at work. My home headphone setup is Bifrost Multibit>Jotunheim>MrSpeakers Ether C Flows, and I'm very happy with how close my travel setup comes to that. My previous DAP, the iBasso DX-90, was harsher in the highs and less impactful in the bass region with the same Etymotic in-ears.
Hope this helps!
