wow just realised how much memory dsd takes up. need to order some some little cards then!
Unless these are SACD's why DSD the file are large and there is no benefit in SQ just use wav or flac and save on file size.
Anybody?
I'll look later and see if that's in my directory. It would make sense that it should be there. An .ini file is a text document used to store settings, and the EQ information has to be saved somewhere. Are you using a custom-set EQ?
I mentioned that on @moedawg140's review thread about the eq file. It's just to store eq settings, as suspected. I don't use EQ at this time, but better to leave it.
Many thanks for advice. I have noticed some of Wav files did not come across saying that format was unsupported. I think i will try wav and flac in future. The click wheel is still irritating in that it jumps randomly to wherever it (not me) wants to go next. Have also noticed that it jumps at the start of some tracks. Still love it to bits though.
Quoting this older post for the newer viewers in this thread. It's not something to be worried about if you notice the percentage number dropping more rapidly towards the end.
Interesting. I forgot that was a discussion earlier on. I was talking with Bruce and he said most users got roughly 9 hours of playtime.
I did a test last night and got 8 hours or slightly less when running 192kHz @ 24 bit depth FLACs. I simply looped the Eagle's Studio Collection album till it drained, noting the time and percentage as it drops. I thought it would have lasted longer as 192kHz @ 24 bits shouldn't be as straining as DSD.
I ran Low Gain @ Volume set at 30. Output was to my Westone W60 IEMs.
Anyone got a take on this? I would like to compile all user experience to note for future reference and if anyone else has questions.
I did email Questyle support and they said it is not norm and I could send it back to distributor for a fix. They need special tool to open the back panel and am not ready to let them do it now.
Yes, check my QP1R review for battery drain times and descriptions.
Very interesting. What quality is the FLACs that you used for the test? When I did 192kHz, I roughly obtained 8 hours of playback while sitting at low gain and volume set at 30. I'm redoing my test to reflect FLACs that are 44.1kHZ to see how much of a difference that will make in playback time.
I remember glossing over the play time when I read your review. I'll post my findings once I get done with my second test. It's a fantastic player and 8 hours is not at all bad to me for something that can play EVERYTHING with no problem. Though I would love to find out how to get closer to the quoted 10 hours and ensure that my battery isn't being gimped/defective at any point. Therefore, reason why I am doing these tests.
Besides, it'll be good info to place in an review or for someone later to refer to it if they have the same questions as I do. Thanks for the read yet again, Moedawg.
My unit has the same issue.
So you confirm that isn t normal ?.
If questyle can confirm that in order to know if we must send back our units to a replacement ?
Thanks.
I would have to perform battery drain tests with every single file format, bitrate quality, and Questyle QP1R settings (EQ on/off, screen brightness, etcetera) with a plethora of IEMs and headphones to start to have a grasp of the specific battery drain times. Also, no matter what the battery drain times I experienced, users will experience differing times somewhat to a lot based on how many battery drains the user performed and users will experience differing times somewhat to a lot based on the age of the users' batteries as well.
Not feasible for me to do, so I will not perform these exceeding extensive tests. If someone wants to perform the tests, then by all means, that would be awesome, as one point of reference.
With that said, getting 8 hours of regular use is completely normal to me. I would not worry about your or anyone else's battery being defective with those battery drain times, and all of the tests that I performed, I was not able to break the 10 hour mark. Maybe if I tested/listened at a lower volume I would get a longer tested battery drain time. Maybe if I tested/listened with 128 kHz files. 320 kHz files. .WAV and differing .DSD files (DSD64, 128, etcetera). Maybe if I used a more efficient IEM and/or headphone. Maybe if I tested/listened via the internal memory and not a Micro SDXC card. Maybe if I used a faster/better quality Micro SDXC card. I do not worry about the maybes at all and use a battery charger if I need more battery power from the QP1R.
