The short answer is that Current Mode Amplification has a wider bandwidth and eliminates Transient Inter-modulation Distortion (TIMD) which is what gives solid state amps that metallic sound. How it does that is a little more complex. In conventional amplifiers, the signal is modulated in voltage mode, which is relatively slow, reducing the slew rate and limiting usable bandwidth. In the majority of amplifiers, THD is reduced using a negative feedback loop, the draw back of which is that the slew rate is not fast enough to correct distortion on transient signals, creating TIMD. Current Mode Amplification modulates current rather than voltage, which is 100 times faster, eliminating TIMD by pushing it out of the audible spectrum, much in the same way that oversampling eliminates digital noise in a DAC. The disadvantage of Current Mode Amplification is that it does not work well with a variable impedance load (like a speaker), so we convert back to voltage mode at the output stage, though no signal amplification occurs in voltage mode. In practical terms, the disadvantage of Current Mode Amplification is a more detailed, less distorted and colored signal which may not appeal to some, especially with headphones designed to compensate for such shortcomings in other amplifiers.
