Questyle CMA600i first impressions thread
Jan 21, 2020 at 4:59 AM Post #526 of 553
Hello,
I'm using the 600i as well but just single ended for the moment and would like to change over to XLR.
Could someone let me know the pin configuration of the Qeststyle's XLR jack?
Would be glad for some help!
Cheers!
Mar 26, 2020 at 12:35 AM Post #528 of 553
Hello, does the signal in the line in input on the cma600i goes straight to the preamp like the cma800i?
Yes it does.
Mar 27, 2020 at 5:42 PM Post #530 of 553
Do they share the same preamp and the difference is only in the dac? or the CMA800i is of a higher quality preamp?
I don't know sorry.
Jul 24, 2020 at 2:24 PM Post #531 of 553
I am writing the Hive mind here. I primarily use a pair of Focal Clear with the Questyle CMA600i. I just saw the promotion Focal is running for $1000 off of the Arche and wondering if anyone can speak to how the two DAC/Amps compare. I would like to hear if the Arche is a significant upgrade over Questyle or not
Jul 24, 2020 at 2:49 PM Post #532 of 553
Instead, just get a new DAC to pair with the CMA600i. The CMA600i is a great Amp, just get a better standalone DAC
Oct 13, 2020 at 10:44 AM Post #534 of 553
I don't believe so if you are using USB. I believe the issue can be bypassed if you use another input like optical. When this issue came to light a couple years ago, Questyle acknowledged this was a hardware-based problem that couldn't be patched with firmware upgrades.
Nov 19, 2020 at 7:17 AM Post #536 of 553
HI is anyone here running ROON with CMA600i, i'm struggling to get Roon to recognise it. Any advice gratefully received :)
Nov 19, 2020 at 8:25 AM Post #537 of 553
Nov 19, 2020 at 11:21 AM Post #538 of 553
Dec 21, 2020 at 7:11 PM Post #539 of 553
Roon recognises the 'Xmos' USB interface on my Mac when I hook-up my CMA600i.
Mar 4, 2021 at 5:53 AM Post #540 of 553
How does the CMA600i behave when paired with IEMs and driven from the balanced output? The CMA400i is "ink black" from its 2.5mm balanced output. No hiss or noise whatsoever .. So I am curious to learn how the CMA600i handles those in the absence of gain control switches like the CMA400i has?
