esauseesaw
Member of the Trade: SCV Distribution
If I use the RCA input on the 600i from my 2Qute, the signal still comes through the amp as balanced, if I understand you right.
Yes, you still get the benefit of the balanced amplifier/hp output.
Questyle advertises the 600i as fully balanced, but according to your explanation it is true only for the amp section. Do you mean by this when using the 600i's DAC, it is not 'that balanced' anymore?
They say this in regard to the amplifier design, with is indeed 'fully' balanced where other products are only offering a balanced connection on the hp out. Let's say you connect a digital source and connect a power amp, active speakers etc, to the audio outs. Then you would be using the DAC and the separate preamp stage, neither of which is a balanced design. It doesn't matter if you connect digitally or analogue from your 2Qute, you'll only benefit from the balanced element when listing to headphones.
So is it not necessary to use a balanced DAC with a balanced amp if we want full balanced sound? Or in this case it is ''balanced enough" to enjoy the clarity that a good balanced implementation brings?
What would be the benefit of using a balanced DAC with a balanced amp Vs SE DAC to balanced amp? Does it really have practical advantages only (long distance as you mentioned) and not much affect on sq?
How long is a piece of string?
