I cannot handle the cable which is too thick so 1960 x2 wire will do.
The ergonomics of the 4 wire PW Audio cables is fantastic.
Yes, no microphonic at all.So 1960 is free of microphonic? How's it compared to leo 2? Have you had leo 2? I think leo 2's great so I will have a hard time justifying purchase
of 1960 at the moment but I like the look of that black cloth cable.
Definitely thinner and more supple that the Janus, I would compared to the Ares ll+ as thickness, but with better ergonomics.How thick is 4 wire? Is it thinner than janus d?
It’s not the best ergonomic cable I have, but it’s not too bad either, i mostly use it at home, but I found that with ciems that have a very good seal the Janus it’s not too bad, while with others like the Phantom or the a6t that are quite light, the Janus becomes quite uncomfortable.Oh yeah. Much better ergonomically and in size. The Janus is a monster and the thickest and most uncomfortable cable I’ve used.
The more popular stuff, so No 5. some of the entry level, Silver Gold, 1960s, 1950's iirc Andrew told me. A shipment arrived Friday afternoon, so order away folks if any tickle your fancy. Sadly stuff like the Blackicon Single Crystal Silver needs to be ordered directly from PWA. I ended up getting the No. 5. from Andrew and the Single Crystal Silver from MTMT Audio in Hong Kong which stocks everything listed on their site. My No. 5 is in hand but the Silver is stuck in express mail.Musicteck now stocks PW Audio cables![]()
PW Audio just released NEW series - MONILE in Hong Kong. There are different versions...
1. Monile standard version.
2. Monile shielding version.
3. Monile feature 50s version.
4. Monile feature 60s version.
Following Monile version is
- Shielding Version
- 2.5mm Balanced
- CM 2-Pin
