DRHamp
Your also welcome to send us the same pic, as we'd need to see what your seeing before we could help at all
Thanks, I'll do that and post a pic in a few and will also email it to Jeremy.
I can confirm that my adapter is about 3/16 of an inch from completely seating also. I don't want to push any harder either. It seems to work ok though.OK guys - another noob Ember question:
I just received a 6SN7 and adapter from Jeremy. The adapter does not seat fully into the 9 pin socket on the Ember. I'm afraid to force it down.
It appears to be approx. 1/8" short of being fully seated.
A question is, is this normal?
Everything appears to work ok - except there is a low level buzz(no input) and some scratchiness when rotating the volume knob above 2 or 3 o:clock.
Is this normal? could it be related to the adapter not being full seated in the 9 pin socket?
I've tried a variety of 9 pin tubes (6DJ8, 12AU7, 6N30P) and had no noise or vol knob scratch.
I get volume pot scratchiness also but I have the input capacitors bypassed so not sure about that one.QUOTE]
The manual mentions that some noise from the volume control is likely with the input caps bypassed. I heard it on my Ember. I decided that the difference in sound derived from bypassing the input caps was not worth it.
Try putting them back into the circuit and see if it makes a difference. I am fairly certain that it will
I have all of the jumpers in their default position but I will verify that the input caps bypass jumpers are in the right position.
Try putting them back into the circuit and see if it makes a difference. I am fairly certain that it will.
I have the vol pot scratching only with the knob at 2+ o:clock and it's not bad - and again I don't have the caps or resistors bypassed. I will experiment a little and bypass them to see if I perceive an improvement with my Atticus HP which are dang good as is. I'll let you know what I think - btw, I wish I could describe the differences I hear as well as you.With my HD 800 and the amp set to Bypass both Input Capcitors and Resistors I don't have too much vol pot scratching, I'm also finding the sounds is a little... less hard with better impact/resolve! Pretty nice actually, I never noticed a difference with my HE 4. The LCD 2 isn't quite as well, so with 35R out and .1R out I don't have any real VolPot noise, but my entire system is running from a Power conditioner so that might help keep things quite
I couldn't find the Emotiva Control Freak available anywhere, guess they have stopped making it.In my case, I don't even use the volume on the amp so the scratchiness isn't a problem. I sit a ways away from it so I needed a solution. The solution was an Emotiva Control Freak. It's a nice little piece of equipment. Feels great and let's you adjust the volume ever so gradually. It really does work well. So, that's why I have the input caps bypassed. Just looking for that little bit of extra cleanliness.
