ugh I'll have to pick up an adapter then, I checked the ampage on the GE 6SN7 GTA an it was REALLY low, so apparently I can use two of them without any issue, only problem is I'm broke :/ I could try to get a return on my VokShod 1975 Rocket [which actually I might due seeing as the shipping date is SO DARN LONG] Chances are it's been too late so, we will see how it goes
if he accepts it an allows for the cancellation I can use those funds to Purchase the Adapter an a Matched set of GE 6sn7 GTAs. I did a little more reaserach today an found that usually when two identical tubes are sold under different brands, it could be because one of them measured poorly, an was liqudated to another company. An other times it's just sold under a different name
so we will see how the set of 6SNy GTAs I got sounds, as one is an Adrmial, but they both measured very well, I posted the numbers up here some where
How does the Dual Set up compare to a single 12V
