Aug 11, 2024 at 1:19 PM Post #1,381 of 1,388
I've just put a 6n6p tube into my Project Ember. Does anyone have experience with the tube. Is it a good one?
Edit: it seems its not a 6n6p tube since it says ECC82 on the tube its rather a 12AU7
Another tube i have it says 6H6N on the tube in russian maybe thats a 6n6p?
Aug 11, 2024 at 5:08 PM Post #1,382 of 1,388
Yes it is. 6H6N is another designation for 6N6P.
Aug 19, 2024 at 11:52 PM Post #1,384 of 1,388
Hey there,
just a question. How do i recognize that my tube is done? I mean at the end of their life cycle?
Are there such indications? If yes which one?
I'am asking because my 6n6p tube is so warm sounding and smooth/relaxed i'm afraid its over it's life cycle.
or maybe thats their sound characteristic idk.
thanks
Edit: anyways i've ordered a TAD Tubes 12AU7A/ECC82. Does anyone have experience with that tube, is it good?
Aug 22, 2024 at 5:50 PM Post #1,385 of 1,388
So i checked the Project Ember against the Schiit Magni 3 and i have to say that with the Ember the sound is more holographic and 3d and smooth but incredibly colored.
I'm not sure i want my sound to be so colored.
The Magni 3 has same bass quantity but is more dry and neutral to the sound. I've ordered a 12AU7A tube and will listen if theres less coloration with this tube.
I'm using these amps with a Chord Mojo 2 and Schiit Modi Multibit and AKG K701.
Anyone have the same experience with tube amps?
Aug 22, 2024 at 8:21 PM Post #1,386 of 1,388
I'll be honest, out of all this time that I've owned tube amp I've never wear out a tube yet.
So I actually don't know either LOL.
Hmmmmm I mean..... coloration is kind of why people buy tube amp lol. That's kind of the point.
But there are less colored tube out there yes. I just don't know which one.
Get THX AAA amp. :laughing:
Or buy LISST (6922 type) for the Ember.
Lol to be honest, Mojo 2 is colored too, same with Modi Multibit.
They are all not linear sounding gear. But I guess less colored than tube.
Aug 22, 2024 at 8:25 PM Post #1,387 of 1,388
I don't know, i think i wanted a pure DAC sound without smoothing it over with a Tube amp.
I've ordered a 3.5 to 6.35 adapter for the headphone jack then i'm gonna check out how the build in amp is of the Chord Mojo 2.
Thank you Hyde00 i will check out the LISST (6922 type) for the ember.
Aug 22, 2024 at 8:54 PM Post #1,388 of 1,388
Oh another thing to check just in case.
Ember has output impedance adjustment, make sure it's on L (0.1 ohm) and not on M (35 ohm) or H (120 ohm).
If you set to L you'll notice you gain more power too, default it should be on this, but maybe good to double check. (Need to check both left and right side)
Setting to M or H will lower power also color the sound too.
Though Mojo 2 built in amp should be decently powerful too.
Good luck and report back later lol!
