timjclark
That's awesome VRacer! I'm completely unfamiliar with that 6H30Pi tube. My two favorites are 12ax7 and 6DJ8 in my Ember II. But now I kinda want to try the one you suggested..
And what's better than a Project Ember? ... two of them!
Just got in a second used unit that came with an electro-harmonix 6H30Pi tube ... price could not be passed up. Both Embers cost me less than a single brand new one would! So now I have one for work and one for home. I tell you what... this 6H30Pi tube it came with is pretty sweet sounding - really digging it! Anyone know the expected life from a 6H30Pi type tube? They aren't too expensive, so I'd be fine buying a couple more if they actually were on the lower end of the life scale for a tube...
I've been searching and searching for any comparisons between Ember and Lyr 3 and haven't been able to find anything. I know there has been bad mouthing about Ember from the Lyr 3 camp on the interwebs. But practically it doesn't help much.
Does anybody have an opinion?
I was thinking of picking up one of these for a Sennheiser HD 660 S. Any thoughts on that pairing?
Have you heard the Chord Mojo with the HD650?By the way, I have tried the following amps since.
Magni 3 - Not as smooth, super small sound stage, weak bass, but has a few advantages over Ember. Ember wins though. Easy.
Sapphire - Not as musical but cleaner, crisper. But doesn’t sound as engaging. Ember won for me.
DarkVoice 336 SE - Not as musical or sweet. But thicker (in a good way) and has a larger soundstage. Ember wins.
MCTH - Sucks. Much worse than a Magni 3 but with a larger soundstage. Ember wins.
Asus E1 Muses Amp section - Ember wins. Muses is harsh.
Headphone was HD 650. DACs varied perhaps but mostly Mimby.
Beta 22 - More musical and sweeter than Ember with deeper and tighter bass. Ember was crisper and more forward. Beta22 was slightly better. But both were very good. DAC was Assemblage perhaps.
It’s quite ironic how the maker of the Ember, doesn’t believe in clean power supply improvements because it isn’t measured on audiosciencereview, yet the differences are very clearA linear power supply for the Project Ember 2.1
There is very little information about how the Project Ember performs when used with an external linear power supply.
I have tried it and I'm glad I did. With a decent PSU the Ember reaches an entirely different level of performance.
I've been somewhat sceptical about the merits of the switch mode supply my assembled Ember 2.1 came with. As far as SMPS go, the GSM40A48-P1J from Mean Well's medical adaptor series is probably quite nice, but SMPS are notorious for the amount of ripple and noise they generate. A couple of months ago I had gotten a Chinese "Zerozone" linear power supply for my old "Pro-Ject DAC Box DS": That worked wonders. Reason enough to try it with the Ember as well. The Ember needs a 48V supply and those aren't easy to find. I managed to get a Chinese power supply via the Canadian Ebay platform. They advertised it as "Finished 65W hifi linear Power supply DC48V 1A / Ultra low noise LPS L6-4". Its R-core transformer is specified at 65W and the Chinese love to quote the higher figure. In reality it puts out 48W though, equivalent to 48V at 1A current. That's even a little higher than the 40W rating of the Ember's Mean Well SMPS. So, if the Ember has higher current draw (which tends to be during the inital warm-up phase of certain tubes with higher heater current) the PSU can provide it.
Additionally, I bought a DC umbilical cable from a different Chinese seller. This umbilical uses a Canare 4S6 Star Quad (speaker) cable and is terminated with a GX16-2 plug on the PSU side and a Oyaide DC-2.1G plug on the amp's side.
The result?
To my ears, the sonic improvement is as big or bigger than anything I ever achieved by tube-rolling. With the linear power supply the Ember sounds refined. The treble has a silkiness that just wasn't there before. Massed strings are simply gorgeous. Another thing noticeable with orchestral music is the far superior resolution. At times, the appearance of more "detail" comes at the price of reduced temporal cohesion and musicality. Not in this case. There is greater musical clarity with the PSU, superior realism and more emotional engagement. The Ember becomes more resolving in the sense that it simply gets out of the way of the musical performance. There's more weight and physical presence to instruments as well. And there's more bass slam. With the linear power supply, the amp has both: superior micro- and macrodynamics.
Now, is it worth it? I paid an additional 50 percent of the price of the assembled Ember for the Chinese PSU plus DC cable (including transport and customs). I love what the linear PSU does to the Ember's performance but at that 150 percent price point there might be other amps to consider as well. And it didn't stop there. I invested in adapters and attenuators as well.
Some background info on my Ember setup. When it comes to tubes, I much prefer 6SN7s with Garage1217's adapter to anything from the noval families. In the Ember, novals all have a somewhat shouty and forward quality to my ears (the Russian 6N6P being least objectionable). I could say I never found a 6SN7 I didn't like in the amp, but actually: My favorite 6SN7 is a Sylvania 7N7, the "loctal" twin of early 6SN7GTs, electrically identical but with the loctal instead of the octal base (a great way to get very good NOS performance dirt cheap, btw). This means I have a loctal-to-octal adapter (by Jacmusic) on top of the 6SN7-adapter from Jeremy. The headphone I use almost exclusively is an AudioQuest Nighthawk Carbon, with modern pleather pads, NightBird Model One cable and the -20dB attenuator plug from Garage 1217. The Nighthwak with its rather low impedance and high sensitivity seems to like the attenuation.
Do I regret the effort that went into tweaking my Ember's performance? No, I'd say it was worth it (as any self-respecting, i.e. obsessed audiophile would). Sonically, I am utterly pleased with the new properly powered Ember. It took me some time to get there. But I arrived.
