This thread is funny because, as someone mentioned earlier, we're basically compiling a list of things that on the whole are quite trivial; but they will probably function for far longer than us mere mortals many times over. It's a bit of a sobering thought.
Mag-Lite: Assuming you can find replacement bulbs and as long as things like 'D' batteries remain relevant, you should be able to pass this along to your grandchildren's children. The seals would require eventual replacement; so if this goes for more than a couple of hundred years, it might eventually lose it's water resistance. This assumes household use, so I'm thinking the switch should last.
Stemware: They haven't really improved upon their design for a while. Wine has been and probably will be around for a long time. As long as the flavors, varietals, and our mouths remain the same, these should be fine. Just don't break them.
Firearms: Assuming they aren't used for military or law enforcement service, these should last a long time as long as they are stored reasonably well. Ammunition stored with similar care should outlast you. But you could keep a reloading rig alongside just in case. I'm sure gunpowder will be available.
Books: Again, assuming reasonable storage conditions and assuming these are things that will only be read a few times (this would exclude reference manuals, etc.), you could pass these on.
BA IEMs: I'm not sure if I missed it or if it was intentionally left out- but how about BA IEMs? I'm sure there must be a thread somewhere discussing the longevity of these. And I'm referring to the MTBF of the armature itself, as I'm assuming that with reasonable care and cleaning, aside from perhaps a frayed or cracked cable the rest of the unit should last at least to the next generation? For this, I would assume a scenario of listening a few days a week for a few years and then maybe every once in a while. I would also assume that there would be some compatible device still left to plug into.
