Precog's IEM Reviews & Impressions
Aug 29, 2021 at 1:33 PM Post #1,471 of 3,716
Speaking of hiss, I can't recommend my Schiit IEMagni enough for sensitive IEMs. It's negative gain stage completely blackens the noise floor.
I know may people use DAPs and phones, I do too. If I were ever to get an Andro presonally, I'd have to upgrade my dongle.
Aug 29, 2021 at 5:38 PM Post #1,472 of 3,716
Flagship IEM Shootout - 64A U12t, Sony IER-Z1R, qdc Anole VX, Vision Ears VE8​
Preface​
The 64 Audio U12t ($2000). The Sony IER-Z1R ($1700). The qdc Anole VX ($2300). The Vision Ears VE8 ($2200). If you’ve ever checked out the world’s largest IEM ranking list, then you’ll know what these IEMs are: they’re IEM reviewer Crinacle’s S-ranked IEMs. Out of a mind-boggling 800+ IEMs that the man has heard, these are the four IEMs - the top 0.05%, the cream of the crop - that have been awarded the prestigious “S” grade. As a newcomer to the hobby, I still remember staring at these IEMs on his ranking list with stars in my eyes and, simultaneously, with a sense of detachment at knowing I’d probably never hear much less own one of them.
...well, stuff happened. A lot. And since then, I’ve heard all four IEMs (and all the “S-” IEMs on Crinacle’s ranking list for that matter). Some of them were heard at different points in time, all were heard for varying degrees of time, and none were heard all at the same time. But thanks to a very generous reader, I’ve had the unprecedented opportunity to evaluate all four of these IEMs against each other from the comfort of my home for the last couple months. Now, I’ll finally be sharing my thoughts on how they stack up against one another. Consider a tribute, if you will, to the world’s most comprehensive IEM ranking list and to some of the few IEMs to have blown me away.
These units were provided for review by a generous reader. At the end of the review period, they will be returned and, as always, what follows are my honest thoughts and opinions to the best of my ability.
The Tangibles​
No better way to kick this off than with the Sony IER-Z1R, which far-and-away sports the best unboxing experience of its flagship brethren. Two cables terminated in 3.5mm and 4.4mm (minus 2.5mm of course; all my homies hate 2.5mm and Sony knows what’s up) are included alongside an endless assortment of tips. The included case is still pretty meh, but it’ll get the job done. All of this is packaged in a box with various slide-out components that’s been mimicked to no end by competing Chi-Fi brands since.
The IER-Z1R also has the build that inspires the most confidence out of its peers. From it’s perlage finished faceplates to its robust zirconium build, it simply makes you think “Damn, I got my money’s worth” when you hold it.
BuildAccessoriesPresentationAverage
9898.66
In second place, we have the Vision Ears VE8. The VE8 arrives in simple packaging that pales relative to the IER-Z1R, but the unboxing experience is solid and commensurate with what one would expect of a flagship IEM. You have a hockey-puck style case (with a rubber inlining, nice!), an assortment of SpinFit tips, a cleaning tool and cloth, and a bottle of cleaning liquid. I’d say the included cable is one step ahead of the 64 Audio cable; that is to say, barely acceptable. The VE8’s build is also just your standard acrylic shell affair, nothing much else to say on that front. Did I mention that the packaging for this one smells really nice, though?
7777
On the other hand, the 64 Audio U12t continues to be a shoo-in for one of the weakest unboxing games that I’ve seen at the flagship level. The revised packaging includes their pleather hockey-puck case, an assortment of SpinFit tips, and the MX/M15/M20 Apex modules. The included cable with memory wire has not changed as far as I can tell, unfortunately. Credit where credit is due, these accessories are better than the affronts to usability from not too long ago, but that’s not a high bar.
The U12t’s body is milled out of solid aluminum. The faceplate, however, can be susceptible to being dented from photos that I’ve seen of other U12ts. I would also like to have seen recessed 2-pin connectors being used, as it is a frequent stress point of the IEM.
7666.33
To my surprise, the qdc Anole VX’s unboxing doesn’t fare much better; if anything, it might even be worse than the U12t. The only difference, really, is that the included cable isn’t nearly as bad as the U12t’s or the VE8’s. I’m not really a fan of the VX’s case. It requires you to wrap the cable around a peg to fit the IEMs which, in reality, is just time consuming and doesn’t have much practical value.
The Anole VX definitely stands out for its build quality, though. It uses qdc 2-pin connectors, which is significantly more robust than standard flush. The switch system is also implemented cleanly, even if it really just means more moving parts for failure.
8666.66
Fit and Comfort​
It probably goes without saying, but fit and comfort are 100% subjective and unique to your ear anatomy. This is just a reflection of how these IEMs stack up for me in this category.
(1) There’s only a few IEMs that I’ll wear for 5+ hours, and the U12t is one of them. The simplicity of the teardrop housing works perfectly for my ears, and once you stack on 64A’s Apex pressure-relief technology, there’s just no contest.
(2) Both the Anole VX and VE8 sport standard builds that more readily conform to the ergonomics of the ear. I do find both to be a tad tight; however, my ears will get through a couple hours of listening without too much trouble.
(3) The IEM with no doubt the most contentious fit is the IER-Z1R. And it’s not hard to see why. The housing of the IER-Z1R is absolutely massive in order to accommodate its large bass driver; consequently, nothing about it remotely conforms to the ergonomics of the average human ear. I started out only being able to listen to the IER-Z1R for half an hour at a time and slowly have managed to get that number up to a little over an hour.
Tonal Analysis​
(1) 64 Audio U12t
The U12t sports a slick, U-shaped presentation with a touch of spice up-top in the treble. Something that surprises a lot of listeners is how bassy the U12t is, but it’s controlled bass and some of the best BA bass you’ll find. The midrange takes a backseat with female vocals, aptly killing any sibilance and striking a dead-balanced note weight. Some, however, might find the U12t to sound somewhat suppressed and to lack bite in those upper-registers. Treble is the most unique part of the U12t’s sound, and what you hear will depend on the limits of your hearing. For me, it’s about equal parts lower-treble and air with copious amounts of shimmer. For others who’s hearing doesn’t token the ~15kHz spike, the U12t will likely sound more dark due to its dip after 10kHz or so.
You’re probably wondering what those Apex modules do. As the number of the module goes up, so does the quantity of bass. In turn, this has psychoacoustic effects on perception of the treble and staging; the MX/M15 modules will give you a brighter treble response and more open staging at the expense of some “oomph” in your bass. The modules are mainly personal preference, and you’ll have to figure out which works best for you.
BassMidrangeTrebleTonal Average
8988.33
Highlights:
  • Excellent BA bass, even better than most DDs I’ve heard.
  • Recessed, relaxed midrange presentation at the expense of being devoid of sibilance.
  • Not for everyone in the treble response.
(2) Sony IER-Z1R
It’s no secret that this is one of the more unbalanced flagship IEMs on the market. The bass shelf on the IER-Z1R is largely concentrated to the sub-bass regions, followed by a near ruler-flat lower-midrange. Then comes many listeners' point of contention: the IER-Z1R’s upper-midrange. The upper-midrange is…forward, mostly, but it exhibits an egregious recession at around 2.5kHz, right in the middle of its pinna gain. Female vocals exist in a limbo of forward and slightly sucked out. Treble on the IER-Z1R might also prove polarizing for some listeners. It’s lower-treble oriented with a strong bump at 6kHz which lends to tremendous amounts of leading impact to percussive hits. The sheer robustness of the IER-Z1R’s treble cannot be understated; however, some listeners might find it fatiguing. Extension, at least, is superb, and with a beautiful sense of trailing reverb.
Highlights:
  • Not a very balanced sound signature.
  • Competition’s slowly caught up, but still some of the best bass in portable audio.
  • Polarizing midrange (correction: the midrange sucks in my opinion).
  • Polarizing treble pending the fit you achieve with the IER-Z1R, but I think it’s awesome.
10698.33
(3) qdc Anole VX
The “tuned by a committee and it shows” IEM of this shootout. But is that such a bad thing? I don’t necessarily think so. The VX has a balanced, but not necessarily neutral sound. It has a clean sub-bass shelf, followed by a slight upper-midrange boost that skews note-weight slightly thin. Something pretty distinctive about the qdc sound is a strong recession at 5kHz. At the expense of some snap to percussive impact, this effectively kills any sibilance and keeps the treble from being fatiguing. Well, that’s what I’d like to say. But in reality, the VX also exhibits generous amounts of mid-treble at 7kHz that lends to a brighter presentation in tandem with the upper-midrange boost.
You can play around with the switches to better suit the VX to your tastes, but I’d really just stick with the stock configuration. The bass switch bloats the VX’s bass quite a lot and just makes it sound overly plasticky. The midrange switch actually lowers the bass, instead, to lend to the perception of the midrange sounding more forward. Finally, the treble switch - yeah, you probably already know what I’m going to say because I already don’t like the VX’s stock treble: just leave that off.
Highlights:
  • Sounds like it was tuned by a committee, and that’s because it probably was.
  • Balanced, but not neutral sound signature.
  • Treble can be fatiguing despite qdc’s attempts to neuter potential sibilance.
6866.66
(4) Vision Ears VE8
The VE8 is tuned to what I would characterize as the epitome of Western tuning. It is a warm, counter-clockwise tilted sound, and those who have heard the VE8 will know that there’s one aspect which this IEM knows no peer in: male vocals. Indeed, anything that tokens the lower frequency bands seems to have just the right amount of texture and crunch to it, lending to what most would describe as a soulful, emotional presentation. It’s far from being a perfect midrange presentation, though, and I’m one of the rare listeners that hears sibilance with the VE8 due to its peak at 6kHz. The “s” consonance, in particular, has a grating characteristic that often pulls me out of my reverie whilst admiring this IEM’s midrange.
The other weak point of the VE8’s tuning is no doubt it’s treble response. It is largely mid-treble oriented - fine - but it really struggles with extension over 10kHz. It’s just not a particularly airy IEM, especially for one that many would deem worthy of “best in the world” status. Intentional by Vision Ears or not - it does lend their IEMs to a warmer listen, after all - I cannot back this tuning decision. The VE8’s treble is consequently quite dull, and it lends to an overly saturated presentation to my ears.
Highlights:
  • Typical BA bass.
  • Thick midrange that plays best with male vocals, but there’s traces of sibilance.
  • Rolled-off treble that is not nearly commensurate with “best in the world” status.
5755.66
Technical Performance​
(1) 64 Audio U12t
The U12t gets some flack for being clinical and overly bland, but I will tell you this right now: It is the most dynamic of these four IEMs. For a sense of scaling gradations in loudness and articulating them with a good sense of weight, there are few IEMs that can play ball with the U12t. The detail on the U12t also comfortably plays at the top, and it has world-class layering and imaging. Indeed, in terms of imaging, it is one of the few IEMs that I have heard with some semblance of soundstage depth, even if it decidedly falls short in the soundstage height department.
That said, note definition is not the U12t’s strongest suit. It skews only slightly quicker than the IER-Z1R in terms of transient speed. Hundreds of hours of listening also suggests there might be a minor sense of disjointedness between the bass and midrange frequencies versus the treble. The tia driver seems to attack slightly sharper in the treble than the ancillary, lower frequencies. This mostly ends up working, though, because the large amounts of reverb and shimmer to the treble matches the slightly slower decay of the lower-frequencies. This slower sense of decay likely contributes to the U12t’s unexpectedly pleasant timbre for a BA monitor.
DetailImagingTimbreCoherencyDynamicsTechnicalities Average
998898.6
(2) qdc Anole VX
I don’t need to listen long to know that this is a very technical IEM. Notes are sharp - almost unnaturally sharp - on the VX, and enough to give me a headache whenever I swap over from something more timbrally pleasing. I also find the detail on the VX to be somewhat artificial; to some extent, the product of its tonality. Nonetheless, there are few IEMs on the planet that compete with the VX in the macro-detail department. The imaging of the VX is slightly above average, but by no means holographic.
Unfortunately, if you’re looking for dynamics, the VX doesn’t really have any. It’s a very flat sounding monitor, and while it has decent micro-detail, it’s micro-dynamics are as flat as its dynamic range as a whole. Music sounds overly loud on the VX and I find myself opting to listen at quieter volumes in tandem with its plasticky timbre. Another criticism I have about the VX is its imaging. The way it fleshes out the center image is unsatisfactory, and I frequently find myself crossing my eyes and looking inwards, somewhere inside my head, to discern the center image. It follows, of course, that the VX has no soundstage depth to my ears.
976957.2
(3) Sony IER-Z1R
The IER-Z1R’s intangible calling card is unquestionably its imaging. It has the unprecedented ability to shape the walls of the stage, resulting in the closest I’ve heard to a speaker-like presentation among IEMs. There’s really nothing quite like it, and at the expense of sounding like a dirty shill, it simply makes you feel like a king. Note definition is also fairly sharp due to the tuning tricks that Sony has played with the IER-Z1R’s tuning.
Where the IER-Z1R mostly meets the short end of the stick is in coherency. This is the bane of every hybrid, and the IER-Z1R is no exception. The attack and decay of its frequency bands don’t match very closely, particularly in the midrange. The IER-Z1R’s midrange is more downwards-sloping to the way it attacks, and it decays with more grit than the dynamic drivers being used to token the bass and treble frequencies. There’s also the fact that the IER-Z1R’s really not all that detailed. It has good surface-level detail due to its tuning, but for a general sense of detail, I do feel that the qdc Anole VX and 64 Audio U12t edge it out.
797677.2
(4) Vision Ears VE8
The VE8 is interesting, and admittedly, I’ve struggled a lot with assessing its technical competency. It noticeably has a decent amount of blunting to the way it attacks; therefore, it is not a strong performer for note definition. And really, that’s just what happens when you have a tuning this warm and rolled-off in the treble. Not helping matters even further is that the VE8’s staging distribution is nothing more than average to my ears; notes come from close to the head and don’t spread out much further.
All that said, I can’t knock the feeling that it does have decent detail and a good sense of capturing smaller nuances in music. It’s just been obscured - heavily - by the VE8’s tuning, so it more closely presents itself as a sense of micro-dynamics. As for whether the VE8’s worthy of “best in the world” level detail, though, I’m inclined to say no. Likewise, timbre on the VE8 is quite pleasant for a BA monitor, but it’s still a way off best-in-class due to a noticeable amount of “grit” to the way notes decay.
767967
Which One is For You?​
Ultimately, while I can break down which IEM is “better” for each subset of sound quality all day, the one that suits you best will largely come down to subjective preference. That in mind, let me water it some more.
If you’re looking for the most “fun” of these IEMs, the one with the most special sauce, then you’ll want the IER-Z1R. But hold up. Demo it first. The fit is highly contentious, and it will make or break your enjoyment with these IEMs. If you can’t live without your midrange, then you’ll also want to give the IER-Z1R a pass.
The IEM that I would recommend to listeners who have no idea of what they want is the U12t. On paper, it is (in my humble opinion) the “best” IEM on the market today. On the other hand, it’s the definition of that kid in school who gets a 90% in every subject, but can’t seem to get 100% in anything. Once you’ve figured out your preferences, a lot of people are happy to move on. Ultimately, a lot of people will say they “respect” the U12t but that it doesn’t necessarily engage them as much as some other IEMs do.
The VX is probably the IEM that will impress most listeners right out the gate, but that quickly gets old. Fun fact: Pretty much everyone I know who has owned a VX has sold it. This is a pretty common criticism of the VX; it is overly clinical in its presentation and does not engage. On the other hand, there are a lot of people who buy it back (and sell it again) because they suffer withdrawal from its amazing resolution. This IEM really is something of a drug.
The VE8 is a difficult one for me to recommend. If all you listened to was country music or literally just male vocals, fine, I can see it working. Maybe. But honestly? I’d recommend just going for Vision Ear’s new VE7. It rectifies the VE8’s tonality issues and I hear a lot more detail on the VE7 that I just can’t bring myself to say the VE8 has. It doesn't hurt that the VE7’s cheaper to top it off.
How Have My Thoughts Changed?​
I have fond memories of hearing each one of these IEMs, and it’s pretty interesting to see how my preferences have changed and my opinions have shifted on some of them.
The 64 Audio U12t was the first flagship IEM I ever heard; due to the COVID pandemic, I was relegated to demoing it from the confines of my car with its owner parked next to me. Sure, maybe it was just a tad underwhelming - certainly not the night and day jump that many had purported flagship IEMs to be - but in mere minutes of listening, I firmly knew I had to own one for myself. My appreciation for the U12t has only grown stronger as I’ve heard dozens more flagship IEMs and realized that there’s nothing that quite tops it all-round.
Bias Score
9
Then there was the Sony IER-Z1R. I remember rocking out to its mouth-watering bass for as many hours as I could over a three day demo period. Yeah, my ears hurt like mad after that, but I couldn’t help myself from thinking, “Wow, I just might like this even more than the U12t”. In retrospect, I’m not as hot on the IER-Z1R. It does several things very well, but falls short in a couple other categories just as hard. I still like hearing this IEM every once in a while, though. It definitely affords a unique listening experience, worthy of its price and then some if your ears are deemed worthy of the fit.
Bias Score
8
I think the Anole VX was one of the few IEMs to truly blow me away. And who could blame me? I hadn’t heard headphones or speakers yet, and the VX’s sheer clarity was just on another level. But I’ve done a lot of see-sawing with this IEM because then I started hearing the flaws: the plasticky timbre, the fatiguing treble, and the imaging quirks. I really did not like the VX for a good period of time. Having revisited it, though, I think it’s pretty alright. It does one thing very well, macro-detail, and it maintains a balanced tonality that is worthy of best in the world status. Not bad if you can find one of these on the secondary market.
Bias Score
7
The VE8 is probably the one that I drank the kool-aid most on. I remember thinking it had detail retrieval comparable to the U12t when I first heard it. Now that I’ve heard it again, I’m not sure how I thought it was playing ball. Even the tonality of it is not a good as it should be, and each time I listened to it for this shootout, it felt more like a chore. Luckily, I think Vision Ears themselves is aware of the aging relevance of the VE8, as their new VE7 addresses almost all the issues I've pointed out with the VE8 in this shootout.
Bias Score
6
Wrap-Up​
If we add up the presentation/accessories, tone and tech averages, the bias score, and then average them, we have the following:
64 Audio U12t - 8.06
Sony IER-Z1R - 8.04
qdc Anole VX - 6.88
Vision Ears VE8 - 6.41
But don't get too wrapped up in the scores. I'm not perfectly consistent (heck, my scoring methodology here is different than my own ranking list which is based entirely on sonic performance). Hopefully, though, you guys enjoyed reading my thoughts on the top IEMs of Crin's ranking list. It's pretty cool that some of these IEMs still maintain their positions as top dogs of the IEM world. Something you might also notice, and that was pointed out to me by the reader who sent these IEMs in, is that these are all flagship IEMs that were released in around 2018. The market is always changing, but these IEMs will remain a "culmination of a given brand's skills up until that point and [they] reflect and take influence from other flagship IEMs on the market at the time". That's definitely an interesting perspective to take, and maybe later down the line, I'll do another shootout like this for another year. Or I'll do a shootout of the IEMs that I think are currently the best in the world instead. Who knows? If if you guys have any suggestions, feel free to float them too. Thanks for reading!
Aug 29, 2021 at 6:29 PM Post #1,473 of 3,716
After reading about some of the most expensive iem's over the last few weeks I'm looking at my Xelento and Andromeda with new found respect. Not going to name which ones have been repeatedly singled out but really glad I haven't shelled out $2.5k+ on any of them. At these prices there really should be more places you can listen first before buying, most shops on-line have warning notices that due to hygiene they can't take back iem's once used, it's a big risk to take.
Aug 29, 2021 at 7:46 PM Post #1,474 of 3,716
Preface​
The Tangibles​
9898.66
7777
7666.33
8666.66
Fit and Comfort​
Tonal Analysis​
(1) 64 Audio U12t
8988.33
Highlights:
(2) Sony IER-Z1R
Highlights:
10698.33
(3) qdc Anole VX
Highlights:
6866.66
(4) Vision Ears VE8
Highlights:
  • Typical BA bass.
5755.66
(1) 64 Audio U12t
998898.6
(2) qdc Anole VX
976957.2
(3) Sony IER-Z1R
797677.2
(4) Vision Ears VE8
767967
Bias Score
9
Bias Score
8
Bias Score
7
Bias Score
6
Wrap-Up​
Sony IER-Z1R - 8.04
qdc Anole VX - 6.88
Great shootout write-up. Thanks @Precogvision! I’m a huge fan of the U12t as well. It really holds up well against even the more recent competition.
Aug 29, 2021 at 9:57 PM Post #1,475 of 3,716
Thanks! There’s a new wave of stuff coming just around the corner, though. I’m really interested to see if something else’ll finally steal that #1 spot for my preferences. Also that’s one crazy collection you have!
Aug 29, 2021 at 10:04 PM Post #1,476 of 3,716
Sony WM1A: Got to listen to this briefly using the Sennheiser IE900. I find that sources benefit from a point of comparison, so of course I used my iBasso DX300. The WM1A has a warm sound signature with a great sense of authenticity to its transients. Notes feel weighted and sport good tactility. The DX300 is more airy and expansive by comparison. Dynamics on the WM1A hit hard, whereas the DX300 leans more fluid for scaling swings. If I had more time to listen in a quieter environment I might have more thoughts, but overall, the WM1A has a very nice sound. It's not hard to see why this DAP has the following it does.
The WM1A is one of my most favorite DAPs, absolutely love it with almost every IEM incl. the Campfire ones despite the hiss (I just pretend I am listening to one of those retro minidisc players). I'm curious to know if your unit had the MrWalkman firmware installed. With the MrWalkman firmware the vocal rendition is simply the best I've heard. Backing vocals are outlined in a manner that's completely unique to the WM1A/WM1Z (and with the MrWalkman fw I think the WM1A gets dangerously close to WM1Z in terms of sound).
Is there a DAP that has absolutely zero hiss with those?
From my experience, only 3 DAPs I've tried don't hiss with those: Cowon Plenue R2, Lotoo PAW 6000, Lotoo PAW Gold Touch. However I always use IEMatch with Campfire IEMs. Most of them tend to sound better with IEMatch in-between.
+1. The VX has the quickest "wow factor" that dampens as you keep listening to them longer and build listening fatigue pretty quickly. I think the biggest issue with the VX is how it shoves everything down the ear-canals and the lack of microdynamics. I like to call the sound of the VX high contrast, since it outlines every instrument but foregoes the natural decay and focuses on instantaneous attack instead.
Also quite interesting to see the Z1R and U12t get almost same scores, though I think if comfort was taken into account Z1R would be behind by a margin.
Aug 30, 2021 at 4:23 AM Post #1,477 of 3,716
I'm still trying to get 64Audio to send me a demo unit of the U12T. They've been quite nice and replying to my inquiries about it, but they just don't have the stock right now. It's hard to go back to other IEMs when you heard how godly the imaging is of the Z1R- but that's basically all it has for me. I've been pretty happy with the Variations right now. I can't wait to see what new things release. The Prisms caught my eye but the price where it's at, it is fighting a tough market.
Aug 30, 2021 at 11:09 AM Post #1,478 of 3,716
Interesting shootout. I own the Sony & VE8 but sold the U12T. In the end it did nothing wrong I just found it a bit boring for my tastes. I respect other peoples opinions on the U12T but ultimately in the end you have to go with your own ears and preferences. I think it's these differences which make the hobby we are in so fascinating.
Aug 30, 2021 at 1:55 PM Post #1,479 of 3,716
Preface​
The Tangibles​
9898.66
7777
7666.33
8666.66
Fit and Comfort​
Tonal Analysis​
(1) 64 Audio U12t
8988.33
Highlights:
(2) Sony IER-Z1R
Highlights:
10698.33
(3) qdc Anole VX
Highlights:
6866.66
(4) Vision Ears VE8
Highlights:
  • Typical BA bass.
5755.66
(1) 64 Audio U12t
998898.6
(2) qdc Anole VX
976957.2
(3) Sony IER-Z1R
797677.2
(4) Vision Ears VE8
767967
Bias Score
9
Bias Score
8
Bias Score
7
Bias Score
6
Wrap-Up​
Sony IER-Z1R - 8.04
qdc Anole VX - 6.88
I've only heard the VE8, and own the U12T.
Being boring is one of the costs of being balanced. I think it's perfect for people who have a diverse music library.
U12T is one of the only iems I have ever heard that has actual layering in its presentation. Some may call this soundstage. The vocals sit snugly in the middle and being consistently loud enough and audible. With the bass boost the tonality makes it great for pop. Extra instruments in the tracks come and go, but they aren't screaming for attention. This is detail retrieval without being intrusive about it. That is one of my complaints about the Moondrop S8 and why there is still a slight gap between it and expensive TOTLs. It's a little too sensitive trebles and details. Sometimes this dude with a triangle becomes the loudest thing I hear in the track. I don't think that was intentional of the artist.
My only gripe about the U12T is the totally-ass-cable (marginally better than a $25 dollar BLON-03 cable) and damage-prone female connectors. Jeez if they could put a JH audio 4-pin screwed on cable, it would be the recommended TOTL of the decade.
Aug 30, 2021 at 5:46 PM Post #1,480 of 3,716
YanYin Aladdin Impressions
I'd like to thank @tgx78 for graciously sending in another flavor of the month for some thoughts. Let‘s dive right into it. The tonality of the Aladdin is surprisingly good. It's about what I'd consider neutral with some warmth by virtue of a slightly rolled-off treble response and a more elevated bass shelf.
The bass response of the Aladdin is alright. Tonally, it’s sub-bass oriented just how I like it. It's reasonably bouncy, decays pleasantly, and has appropriate texture. So why is it just alright? I can already hear you thinking. That's because my biggest critique would probably be slam. The Aladdin’s bass sounds overly soft and polite, and I really think it could use with some more aplomb when it comes to more bass intensive stuff. The qualities of a good bass response are generally there; the Aladdin's subwoofer is simply coming up empty-handed in what matters the most to me. Moving to the midrange, there's not much that needs to be said. It's eerily reminiscent of Antdroid's target, hitting just under my perceived neutral in terms of presence. No problems with sibilance, no lower-midrange bloat, just...well-done. Credit where credit is due, the treble tonality is also on-point and devoid of any egregious peaks or valleys. It could obviously use with some more extension, but the same could be said for most all IEMs at this price point. Overall, really solid tonal balance that sets a good leading precedent for the Aladdin.
Here comes the major caveat. The Aladdin's just not very technical. First, I find the Aladdin to suffer from low-level detailing. Attacks are quite blunted which serves to mask some timbral inconsistency issues between the DD and the contrasting BAs. So sure, the Aladdin's smooth. A little too smooth. Dynamics, something I usually refrain from talking about with these IEMs, merit comment on the Aladdin by virtue of how bad they are. They're almost offensively soft and, in tandem with the more laidback tonality, the Aladdin's quite the dull listen at my normal listening volumes (~70dB). I do find myself wishing for more upper-midrange presence and bite to the treble despite my positive comments about the Aladdin's tonality. For other technical metrics, the Aladdin's imaging is pretty alright, but it neither really grabs my attention nor is it enough to distinguish it from the pack of mediocrity. I'd need to grab my Moondrop B2 for direct A/B comparison; however, I'm almost certain that the B2's sports better layering chops.
If it's not already apparent, here's my overarching dilemma with the Aladdin: It's a generally boring transducer being propped upon its tonality. The competition is incredibly stiff at $250, and the Aladdin’s strong showing on the tuning front is not enough to bring it relevance in my eyes. The Audio Lokahi, for example, was more technical than this from memory and sported reasonably good tonal balance. And I only bring up the Lokahi because it's a similarly priced offering from an upstart brand - there's plenty of other stuff out there like the Hana 2021, Drop JVC HA-FDX1, and Etymotic ER2XR that simply eclipse the Aladdin for less. But at the very least, the Aladdin is not a train wreck and YanYin has shown that they can tune. Half a bonus point for showing potential.
Score: 5/10
Aug 30, 2021 at 8:41 PM Post #1,481 of 3,716
Score: 5/10
Oof, that's quite the good example of how something can do everything right on the graphs and still come out lacking. Thanks for the review!
Aug 30, 2021 at 9:11 PM Post #1,482 of 3,716
I want to preface this by saying that I am a novice in these matters, and I could easily be way off base here. But my thought is that in this case the tonality is actually (at least part of) what’s holding back the technicalities. There’s significantly less pinna gain on the Aladdin than most units I’ve tried, and it seems to me that the general restraint from 2k-4k could very well be responsible for the perceived lack of detail and softness of attack. In other words: I can’t have my cake and eat it too.
Aug 30, 2021 at 10:00 PM Post #1,483 of 3,716
There's definitely a big point of contention between tonality and technicalities. I'm not an expert on it myself, but there are a lot of people who believe that every aspect of sound is captured by frequency response, as IEMs and headphones are minimum phase devices. Crin has a good write-up on it here.
You're right about the 2-4kHz recession in that it plays a role in perceived technical performance. Recessing the presence region will usually make a transducer sound less detailed (or at least less "in-your-face"). But then here's where the distinction between tonality and technicalities comes in, assuming you believe technicalities are more than just frequency response. There's plenty of stuff I've heard that recesses the presence regions and yet manages to sound incredibly detailed. For example, the Andromeda 2020 has sharper attack transients in the midrange than the Aladdin, and it's even more recessed in that region! It's the same idea with something like the Sennheiser IE900 which sounds way more dynamic to me despite the fat scoop in its upper-midrange. And as a more extreme example, you could also look at the Audeze stuff. Most of them have basically no 2-4kHz, but they're still incredibly resolving. That makes me think you can have your cake and eat it, it's just a question of if you believe technicalities are more than frequency response.
Aug 30, 2021 at 10:15 PM Post #1,484 of 3,716
Yeah, and the fact that my experience is pretty much solely in budget and mid-fi means that I’m really not qualified to discuss these things. I firmly believe that there is at minimum an interplay between tonality and technicality: in the price ranges I swim in this can be readily observed, and it seems to me as I said that this is at least partly what’s going on with the Aladdin. But it may very well be true that there can exist drivers and/or driver implementations capable of producing an identical tonality to the Aladdin without the technical shortcomings. Maybe I could have my cake and eat it too… if I were rich enough!
Aug 31, 2021 at 12:39 AM Post #1,485 of 3,716
Good points here. I used to wonder about that, then I realized a lot of budget CHIFI like to boost the upper mids and treble to give more perceived details. Some might even go so far as to call them "fake details".
So boosting the upper frequencies increases clarity and that is a function of tonality yes. But clarity is just one aspect, as there are budget CHIFI with boosted upper mids that only have good clarity, but are weak in micro-details, imaging, instrument separation. eg BLON BL-05 (non S version).
Then there are neutralish treble types or as @Precogvision pointed out with the Andromeda 2020, that aren't that boosted on graphs for the higher frequencies, but they still have good technicalities in other aspects than clarity per se. A lot of stage monitors are actually tuned neutralish (so as not to colour the music unnecessarily) and they pack great micro-details inside without being artificially boosted.
I consider micro details to be stuff like ghost notes/ghost hits of drums, breath sounds of singers, squeaks on guitar/bass frets, even fine details like birds chirping/traffic/coughs/things being dropped in live performances. The thing about details is that once you have heard this particular detail in a track, u will know that it is there in the future when u play the same song, and realize some IEMs don't show that particular detail well, even those with boosted upper frequencies.
