FallenAngel
Congrats, it's a very nice amp.
For the PSU caps, using electrolytic caps made for signal coupling is not recommended (BlackGate N, Muse ES, etc). Going with Elna Silmic II is definitely an option, but I personally wouldn't bother with going above Panasonic FM, they're very good PSU caps.
Cat5e is also OK, but not the best. I would recommend using a nicer wire like surplus SPC from eBay (Silver Plated Copper) - it's cheap and sounds much better.
Originally Posted by slaikan /img/forum/go_quote.gif Hi Finished building the PPA v2, very very happy with it, no problems with the build which I'm thankful for since its only my third DIY project. First was the CMOY (recently destroyed the OPA2132 with reverse polarity... oops), then the Audiosector Premium USB DAC and now the PPA. I struggled more with the casing and getting everything to fit properly than bulding the PPA itself. I used all the standard components off the Tangent parts list except for C5's are WIMA MKS4 250V 0.1uF as thats all I could find in a hurry at the time. For those who have experience with different caps, should I replace them with WIMA MKS2 63V 1uF or maybe something else and how much do these caps affect sound quality? I'm using Panasonic FM throughout, 220uF 35V caps on the input side and 3x 680uF 35V on the power supply side. Is there a significant difference with 'boutique' caps like Blackgates, Nichicon Muse, Elna Silmic etc. cause its quite difficult to get that where I stay, so it all needs to be imported. What are you opinions of using CAT5e for hookup wire, thats what I'm using at the moment, I decided not to import fancy hookup wire and my perferred local supplier only sells hookup wire in 20 meter reels, per colour... Thanks |
