Well, I had watched your tutorial video some time ago yes
What really surprises me with the soic soldering is that I had had no trouble soldering the REG101s of the AlienDAC, which are roughly the same size, by using flood and suck with my soldering braid
however, with the ad8610 and the browndog adapters, I simply failed :
way too much solder gets into the pins of the 8610, and when I try sucking it with the braid, it doesnt get the bridges that the solder made between the pins of the ad8610, yet the chip get really hot
plus, when removing the ad8610 that I hadnt properly placed, one of the pads of the browndogs moved a bit. So I guess its dead.
anyway, my issue probably comes from the iron and solder I'm using :
a cheap (8€) 40W iron, not adjustable and 1mm solder 60/40
I m probably going to try ordering this :
MET@SHOP
the tip is 0.6*0.8mm and I think it s a hakko clone, so should be good stuff. Or I ll get a 15W weller
and if I still cant solder properly with this thing, well I ll resort to buying the ad8610 premounted
once more, thanks a lot for your help and your advices tangent
