bigshot
Magnet factories and air conditioners won’t be fixed with a power cord.
A magnet factory might be, but it would have to be producing hugely powerful magnets and right next to the wall of your house. You’d probably be better off with some sort of faraday cage or you’d need over-shielded power cables throughout your house.Magnet factories and air conditioners won’t be fixed with a power cord.
There’s always differences between cables of the same length/type but they’re in the order of hundredths or thousandths of a dB, way, way below audibility. The difference between 18 and 12 gauge cable would be bigger but still well below audible unless the power output of the amp was high, impedance of the speakers was low and the cable length required a lower gauge than 18, which presumably it didn’t otherwise for a few extra pennies they’d have supplied the correct gauge.There's zero difference or none that would be audible?
Are you saying that the $5 18 gauge cord that comes with the amp is just as good as a 12 gauge shielded cord that costs $150? There's zero difference or none that would be audible?
https://www.head-fi.org/threads/ps-audio-perfectwave-ac-12-power-cable.886654/yes yes i know..
what i cant get my head around with fancy power cables making a sonic difference is the fact that household wiring to the plug socket/outlet is plain old commercial household wiring and more than likely loose/ish terminals in the back. or is there some fairy dust inside the fancy cables, or is it just bragging rites and eye candy.
please explain...
It's a waste of money (but then again, it's your money).When I buy upgrade cables it's for better build, better materials, better handling qualities, and appearance. I don't expect they will improve the sound quality, so I'm never disappointed. I got what I bought it for. Anything else becomes a bonus.
You completely misunderstood meYou quoted me for some bizarre reason but you seem to be doing pretty well contradicting yourself. Quit trying to argue with me
You have a conflict with yourself
I'll survive itI tell you what- you can say whatever you want, because you just went into my ignore list. Buh bye
