I've seen it explained on OCUK before, it's basically something to do with how they share what you see on screen, and that essentially the tech used has a ton of room for improvement but nothing much has changed over the last few years, although scaling on multiple cards has improved a lot, so it's there's way less diminishing returns there.
Not sure what card I'll get myself but it'll probably be either a 6950 or 570 overclocked to 6970 or 580 speeds, depending on price and which overclocks best. If an OC'ed 6950 comes within 5-10% of a stock 6970, then it should hit that sweet spot of giving you lasting high performance but without paying full wack every time you need to upgrade (which should be when you can't max a game you like, not every time new cards come out!).
Nice monitor btw, I'm torn between that and the new BenQ EW2420 in the 'quality for a guy on a budget' price for the Mac Mini I want to get. Different panel tech but neither is TN and they both seem very, very good for the price. I'd love the Dell Ultrasharp 24" but it's rather expensive!
Yeah, the last time I heard complaints about micro stuttering was in the 9800gx2, lol.
I'm probably just going to stick to my current card(5850) for a few years, but if the price is right I may do the same thing you're planning on doing.
Thanks, I can't help you too much with your decision since I don't know anything about the BenQ, but I'll give you some impressions of the u2311h.
The colors on the display are beautiful and accurate like you've read, I'm sure. The only complaint I have with the u2311h is the fact that it can only run 1080@60Hz. I don't know how much you care about monitor Hz for gaming(if you game at all), but I got used to it and I also want to point out that the response time isn't really that slow. I did notice ghosting when I first got it, but after a week it didn't bother me at all anymore. Hope this helps you in your decision between the two.
The build quality of the monitor is superb, aswell. The screen only wobbles a bit if you like, say, bump the table by accident. It also has a ton of adjustment options.
The OSD is easy to navigate for adjustment of the colors, brightness, and so on.
I just can't say enough good things about this monitor. If you ever see the deal for it again, don't hesitate to pick one up...I didn't
Hope helps you make your decision.
