yeahx
- Jan 21, 2008
Nope!
this ok? full HD
Look close!
I've been trying to get my turntable to play upside down for years with no luck. Perfect for changing songs while laying on your back.
This looks serious - congrats. VPIs are rare over here - how much does it weigh - the platter in particular ?
But it is a pity they did not allow for less than optimally shielded cartridges to be used - that hum is a no-go. Sonata is such a nice sounding cartridge ... IIRC, it has been jumping from table to table at your place, wasnt' it ?
Platter = 20+ lbs, total weight is 65lbs.
Yes, the Sonata has been on a MMF7, TT15-S1, Scout and the Classic. Even on the previous three tables it probably only has 200-250 hours of use. This week I received the Goldring 2400 (Slightly Used) and a new Clearaudio Virtuoso Wood. Unfortunately there is an issue with the 2400, it has a bad hum on the right channel, hopefully the seller will be cooperative. It's too bad because it seemed to be a good match for the table, perfect weight, high output, replaceable stylus. I spent hours troubleshooting, on both tables and arms, and it always comes back to the right channel. I think possibly when the seller removed it, one of the leads might have come loose inside the cartridge itself.
So I broke down and cracked the seal on the Virtuoso. I haven't had any real time to listen but the two sides I did sound promising, and it's dead silent. Can't wait to really put it through it's paces.
this ok? full HD
Look close!
I thought you managed to take a photo of the cartridge suspension/arm mass resonance :
https://www.youtube.com/watch?feature=player_embedded&v=3ZN7J8l6Q64
What it basically does is measuring the compliance of the rubber suspension of the cantilever. Since the other variables are known or measurable. But that is not all there is to setting up a TT with cartridge.
You must be the most patient man in the world. I'm not saying you are, but that was my suggestion.
It might be usefull to attach a small protracting rod on top of the screws heads. That way if you set the tip at the right point you can line that out with a large visible parallel line. That will help in 2 axises.
