I will write a review for the Burson Audio V5i dual opamp in the related thread when I fully complete the testing however it does not take more than one day to realise that in comparison with the shipped opamp of the little bear the Burson Audio is a game changer regarding the sound quality.
So I totally agree with other people in this thread that already said that they find the change of the op amp as a must. It is a real game changer.
Only negative thing is that in my (our) case, yes the battery life is shorter when this opamp is used with the little bear. But this is related to a specific case and thus I cannot deduce points from V5i because of this.
I experienced a lot of dramatic improvements lately with one being using balanced cables in combination with my Radsone es100 Bluetooth adapter instead of regular cables. The improvement in sound quality was dramatic not because of the balanced cable per se but because of this particular device working so much better in the balanced mode. However, using the same cable with a small adaptor that converts balanced to unbalanced in order to be used with little bear, the change in sound was even more dramatic with the new opamp from burson audio installed. This new opamp drastically transformed the sound after one day that was being installed. It was simply like I was changing amplifier in my main system.
Similarly, going from a crappy AV onkyo budget amplifier to my Marantz 6005 pm in my main system I noticed the same improvement with this new opamp. Or is like going from a budget Marantz stereo amp to using a Hegel amplifier. The reviewers before me were really spot on when they describe that the most notable improvement is associated with the clarity in the guitars and in musical instruments in general. Separation and analysis is on another level.
But I have to say that I feel that the little bear is not exploiting fully the dual V5i. Currently, I am wondering in which device I could place this opamp which also would use a linear power supply in order to exploit fully the dynamics of this opamp. I have the intuitive feeling that it needs more power to further shine.
Obviously, my limitations as a reviewer is that I do not have other opamps to compare. I was looking at sparkos before but personally I would NOT pay around 80$ for an opamp for the little bear. The price of Burson Audio seems very reasonable in comparison. Also, the Burson audio has a nice beautiful silver cap that helps also with the orientation in installation that I think sparkos does not have. So I already did my choice before receiving this unit and from the point of view of a "customer reviewer" I believe that V5i is a no brainer for someone that has already the little bear b4 and as far the sound quality is conserned.
I have no xDSD in at the moment for testing to compare with the little bear + Burson audio opamp but this might change in the future. That would be really an interesting comparison since I have in such high esteem the xDSD and ifi audio products in general. However, although is quite early in my testing I would not exclude the possibility that a es100+little bear+burson audio V5i could be a giant killer when the cost is also put under consideration.
I am very grateful to Charles and the Burson Audio team for providing me this opportunity and I will write a proper review in the following weeks.
A final point I have to make is unrelated to this opamp and is that also to my big surprise the analogue cable connecting the little bear with my source makes a difference!!! Although, I was so happy having this small 10 cm cable provided I discovered that a budget 3m from Amazon circa 7£ improve the sound considerably. My point is not going crazy and spend money in audiophile expensive cables but if a cable is super super budget might influence the sound. And I believe not all of us we have the same generic cable provided. I just used by accident one budget Amazon 3m cable that I just happened to have and the sound was better even if I was going from a 10cm to 3m cable!!!
