samanthaj1820
Hello all! I'm hoping to get some help/advice on what headphones to buy.
I am currently looking at B&O Play H2 On-Ear, 1More Triple Driver and Audio-Technica ATH-MSR7GM. I can get the first two from Amazon for less than £100 which is ideal as far as budget is concerned but would consider forking out more for the ATs (£148). I'm also a bit wary of the 1Mores, as the cable is non-detachable and I'm not the most careful person where wires and cables are concerned.
I would mostly be using the headphones with my HTC 10 (sometimes my MacBook or a cheap-ish Packard Bell desktop) and would mostly be using them during my daily commute, as well as in the library.
I would be listening to classical music almost all of the time, mostly large-scale orchestral works with some chamber, solo and opera thrown in the mix too.
