miow
Member of the Trade: X-Elite (Headphone mods)
aka dimitri42.
- Jan 11, 2010
Thanks guys. You are making me buy RE0...!
I'd say they're both fun, but with the RE0 I just enjoy the music and forget about the phones, while with the TD100 I enjoy the music but get distracted once in a while with the odd sound here, the lack of detail there.
Ok, got my tips and found decored olives pushed all the way over the nozzle and against the body worked best for me. There's enough surface area that they aren't the problem they usually are in staying put. Makes for a shallow and good seal without the soft tip blocking the nozzle. Someone else should check this as I can't go back but sealing the cable opening with silicone seemed to improve the bass. I only find them slightly warm and otherwise nicely balanced with vg but not absolutely top notch detail. Sounded pretty funky with some tips but good with most. Always surprises me.
TD100 have an impressive sound. I had Sennheiser IE8 and TD100 sound better. Sound is cleaner, brighter, better clarity, mids have same quality and bass puts more wheight on sub-bass, providing more real sub-bass which is great. I love IE8's anyways. But TD100 are a bit better IMHO.
