plakat
Whats the pricing on the balanced cable?
Something like €320,- as far as I remember...
Over 300€ if remember correctly from asking when I placed my order.
I didn't buy it because I never heard a difference between balanced and singel ended anyway, not even by comparing 2 identical headphones on a single GS-X MkII using both inputs and switching and mixing around.
but YMMV.
If I would want a balanced cable I'd pay the extra 30 or 40% for an aftermarket one I guess. From a decent brand, not the "We make super space age cables because we have a 90% margin on them." kind of cable. The good ones come in a variety of price categories just as well as the bad ones.
What cable makers do you consider good for aftermarket cables?
Yep and I also don't like the fact, that they only offer it with the stupid 3-pin XLR connectors. I guess they still don't offer an alternative to push their U-05 amp/dac. The U-05 is really good, however I would like to check the M1 out on my other amps featuring balanced options as well.
I have to say I do like the MSE1 in balanced with the GSK MK2. I'm using the Mirus balanced into the GSX so I'm guessing the signal may be improved.
That said I haven't tried single ended with the fantastic Eddy Current Appleheadmay has, I would think that would be a pretty awsome setup.
The MSE1 sounded dam good in my Grace M903 single ended too.
Much of it comes down to preferences Tim.
I had the same GS-X Tim had and while I must say this is a real quality amp that's very capable I found it too clean for my taste bordering on sharp, for my ears that is.
Indeed, I am a huge fan of the Zana, be it the SE or the S. Never had the original. It bests all the amps I had or have heard of which some even twice the price.
I got the Black Widow for a couple of weeks now but only listened to it for about an hour yet and only gave it a day of burn in so take my following comments with a bit of salt.
I find the Black Widow very good but not at the level of the Zana. It has the EC house sound though. Still, I would position my vintage amps, even the little Aiwa between the Black Widow and the Zana. For now that is.
To me the Zana is a now brainer. It's a real high-end (whatever that is) tube amp at a much more than fair price and it drives any headphone I ever hooked up to it to great satisfaction. And that's a lot of headphones.
I do read though that difficult phones like the HE6 and K1000 need more grunt. I have experience with the K1000 (owned one hooked up to the speaker outputs of a class A amp) and some planars like LCD-2 and XC abd heard all the other Audeze but only one HiFiMan (540 I believe, if that exists, wasn't a fan).
For those difficult to drive cans I'd consider a simple vintage amp regardless of output power and hook it up to the speaker outputs. Careful with the volume knob then, those things have some serious output power.
The 40W Aiwa for example drives my PM1 bookshelves just as easily as my 4k 165W Marantz PM1. It has problems with my vintage Infinity Kappa 7 floorstanders though but so does the Marantz, these are monsters to drive. My vintage 165W Pioneer SX-1250 drives them without breaking a sweat but you should see the power supply and power caps in that thing. They're exactly the same the 275W SX-198O uses.
I can't recommend the Zana and decent restored vintage amps enough.
Man do I ever get right off on vintage receiver pics! The vintage thread is so awesome.
I'm hoping if things line up over the next year, after having taken a serious kick to the sack this past month, I'll be able to get a nice vintage amp for headphone listening. I really want to test the assertion that basically all headphone amps are under spec'd and a full on receiver should sound top tier. Off the taps, of course
I'm actually waiting to get cables sorted so that I can try my SEM1 with my new Xindak A600 integrated I bought for my HEK. Though the HEK aren't as current hungry as the HE-6, they sure do improve when there's more on tap (zing), and so I wonder if the SEM1 will too?
Has anyone braved speaker taps and their Precious yet? Like Appleheadmay said, as long as you're careful with the volume knob, there's really no worry.
Hi Appleheadmay I'm also a big fan of vintage amps - I use a Sony TA-N7 VFET power and the incredible Sony TA-88 pre with my NS-2000s. Unfortunately I can't use either of the Sony's with the SEM1 as I don't want to risk using speaker tapsI have yet to try the SEM1 with my Leben CS300xs with nos tubes. I'll give that a try next time I'm home. I heard the EC Zana is also a match made in heaven for the th900s as well.
