Benny-x
Nice, welcome to the club.Hi guys,
I will have the HP next week, I would like to change the cable to balance, should I buy the original cable or can you recommend me some?
I personally do not recommend the Pioneer balanced cable. The sound signature is generic, but the other issue is the outer cable sheath fraying or opening, and the inner cotton sheath coming out. It's not too bad if you don't pay for the cable, but if you're finding one then I'd get a custom one made.
One issue, though, is that the SE-Master1 uses an MMCX connector, which is only common on Custom In Ear Monitor earphones. That's not hard to find, but you might need to actually discuss it with some builders as they may take the topic cautiously. Good luck either way.
