Pioneer XDP-300R | Twin DAC ES9018K2M | Balanced Out | Android | MQA | 2x MicroSD | WiFi | AptX
May 14, 2018 at 3:26 PM Post #1,696 of 2,535
Wow that's very detailed but I dont get 90% of it :) looks like wide is cutting off some high frequencies correct ?
May 15, 2018 at 7:33 AM Post #1,697 of 2,535
wow! what a detailed series of reports. makes your head spin.
i did figure out enough of it to see that my sennheiser 6xx's are good for using with the player in environments where noise bleed doesn't matter.
but then again, there's like 200 other headphones on that list which means their results were pretty scatter-gun. or thorough i guess, being charitable. :)
/guy
Now, the Selection takes into account the characteristics that directly determine the optimum volume range. The selection will be improved. The next step is to analyze the frequency response for simple reports. This is the detection of "bass", "flat", etc. headphones. For streets and noisy places, priority will be given to "bass" headphones. For home and studio - "flat" headphones.
May 15, 2018 at 7:57 AM Post #1,698 of 2,535
May 15, 2018 at 8:21 AM Post #1,700 of 2,535
I did not understand the question (English is not my native language), please explain in more detail please
Hello, I would like to know what what is best filter (short, fast, slow) and best setting (narrow, wide, normal) to use for iem with low impedance
May 15, 2018 at 9:18 AM Post #1,706 of 2,535
It takes trained ears and ab comparisons to hear the difference in change in the fr curve. Some might not hear it that's why you should ab. Some frequencies will get boosted or reduced by impedance mismatching, most wont notice I think
May 15, 2018 at 10:47 AM Post #1,707 of 2,535
it seems, looking at the report that the high impedance output in balanced mode of the pioneer could affect the FR of fIIO F9 PRO (hybrid , 23 ohm). @romanrex am i correct?
I wouldn't worry, my AKG N40 are Hybrid 20ohm and sound stellar
May 15, 2018 at 4:19 PM Post #1,708 of 2,535
I've been very pleased with my purchase of this DAP but when I picked up some balanced cables from Moon Audio for an Audeze iSine10 and put the DAP in A.C.G mode it is bliss. This is the first time I've ever listened to music with balanced cables. I had to see some youtube videos on what makes them different.
May 15, 2018 at 4:44 PM Post #1,709 of 2,535
can the 300r use the sandisk 400gb micro sd card? reason i ask is that they're onsale at amazon and b&h today for $159.
/guy
