Lurk650
Have never heard a Shure so I can't say.Awesome, how would you compare the treble to let say the Shure SE215? I'm wanting to buy this Pioneer IEM.
You are talking the Shure right? Mids are not recessed in the Pioneer lolHave them, they're quite v shaped. Recessed mids. Good staging, imaging and clarity though!
Pioneer. Lol. I have them and they have definitely have recessed mids.You are talking the Shure right? Mids are not recessed in the Pioneer lol
I have them as well. I hear them as forward a bit. We all hear differently though.Pioneer. Lol. I have them and they have definitely have recessed mids.
To my ears, they sound like Black - Black LZA4 in tonality.I have them as well. I hear them as forward a bit. We all hear differently though.
Any iem that you have that you can compare?I could not resist, treble is actually enough and decent, bass is deep. Happy with the purchase.
These have been my gym IEMs for the past couple of months, paired with my Fiio M3 it's a perfect combo. The stock cable is great but started to untwist at the bottom so I switched to my CA Lyra II cable since I'm running those with a cheap Chinese balanced cable. The Litz cable gives increases the treble a bit, so that gives off better resolution IMO.
Do you know where I can find the frequency response graph for this?^^ for those experiencing recessed mids, it is surely a fit issue. The Stock tips are no good for me. I use other tips and mids are no longer recessed. You can also wear them down-ways and switch L & Right -- i get neutral mids this way if I want to use smallest stock tips.
For using non stock tips, avoid using narrower bore/nozzle size. It will reduce the treble & openness and IMO ruin the ch9t sound sig.
That's exactly CH9T's sound signature, as long as you get the right fit.I am looking to buy the ch9t. Are the mids really as recessed as some say? I want a moderately neutral and natural sound with a little boost in bass.
