Apr 22, 2014 at 7:51 PM Post #11,491 of 37,658
Thank you Rudi.
Wish you a great success on the LCD trip!
Thank you
LCD XC is brighter and more detail compare to LCD X
Hugo is also bright sounding amp and detail
If you like bright and detail , than you Will Love
AK 240 + IBasso DB2 > use optical cable
DB2 + Hugo > use Coaxial cable > LCD XC has Excellent SQ
Personally i prefer LCD XC than LCD X
IMO
Apr 23, 2014 at 8:36 AM Post #11,496 of 37,658
Hi Michel
For use coaxial cable between AK 240 and Hugo , you need external dac like IBasso DB2
AK 240 > use optical out to DB2 > use coaxial cable from DB 2 to coaxial In Hugo > LCD XC
Hugo strong Point is their coaxial input
I am sorry forget to put DB2 as media For using coaxial cable
Thanks Rudi for your detailed answer.
Do you really hear a SQ différence between AK240>optical-HUGO and AK240>DB2>Coax-HUGO ??
How Will you describe the sound difference ?
Your set-up is tempting, but is it Really Worth the added complexity & Bulk ?
Apr 23, 2014 at 1:57 PM Post #11,498 of 37,658
Bored.  Took my DHC interconnect to the parlour for a makeover...  Hahahaha....
I really want this DIY interconnect, I found only some similar examples for 100+ bucks on ebay :/
Apr 23, 2014 at 2:22 PM Post #11,499 of 37,658
Hugo best SQ is coming from Coaxial input
Like I done with
As transport :
Source : iPhone 4 s / iPhone 5 s
Dac : venture craft go dap dd 1 LE muse 02 , I use only as USB to SPDIF
Going to Hugo use : coaxial cable
As DAC and Amp
Dac / Amp : Hugo , I use as DAC and Amp
This way is almost the same like with ak 240
IMO
Apr 23, 2014 at 4:37 PM Post #11,502 of 37,658
Today's travel rig
Apr 23, 2014 at 4:58 PM Post #11,504 of 37,658
To be honest kh, I've had this LOD
for so long I don't remember where or from who I got it
 I can tell you I was mad as a hornet when I got my 7th Gen Nano only to find out it would not pass signal thru the Apple lightning adapter
 But alas my $9.00 FiiO did so I just run this on pre lightning rigs!
Apr 23, 2014 at 5:06 PM Post #11,505 of 37,658
for so long I don't remember where or from who I got it:xf_eek:  I can tell you I was mad as a hornet when I got my 7th Gen Nano only to find out it would not pass signal thru the Apple lightning adapter:frowning2:  But alas my $9.00 FiiO did so I just run this on pre lightning rigs!
Yeah, it was hard to see in the last picture. Yeah, I hate it, when you have to keep spending money, on stuff, that should be configured better.
