Jun 22, 2013 at 8:29 PM Post #4,966 of 38,951
In the end you are probably right bro but I like to MYTHbust, think of it like this
Apple put that awesome dac in the ipod video because it was more entertainment based (watching videos/movies) and they accidentally made an awesome music player
But... The first gen itouch which came very shortly after the 5.5 was even more entertainment based (so you see my interest now?)
More than likely apple had some kind of a contract deal with wolfson so a high end dac would probably cost about the same to manufacture as a crappy one, you know they're goal was only to improve
So I went ahead and sent my 5.5 out for an internal Imod and also bought a 32gb 1st gen itouch in mint condition.
I will construct a very honest and detailed comparison between an IMOD 5.5, a regular unmoded 5.5, a 4th gen itouch 64gb, and a 1st gen itouch. All will use line out, same amp/switches, same cans, same exact music files, same LOD cable
I know the itouch has better wiring and circuitry than any ipod video, ... This shall be EPIC
Everyone says the 1st itouch sounds like crap but c'mon man REALLY!? Why would any other itouch sound better?
You are aware that the imod 5.5 needs an LOD with capacitors in, right?  If not your amp might explode!  (I don't actually know what happens when you don't use capacitors but am led to believe it's bad
)  Using the capacitor LOD with the non-modded ipods will make them sound slightly worse...
Jun 23, 2013 at 12:30 AM Post #4,967 of 38,951
My Fostex HP P1 set up
Source : IPhone 4 S
Dac : Fostex HP P1 as dac
Amp : WAGNUS Epsilon S japan
Iem : Fit Ear MH 335 DW with 000 cable
Cable : Lod to USB diy silver cable 8 braid
Tralucent Audio UBER cable mini to mini
Pelican case 1020 USA
Jun 23, 2013 at 12:33 AM Post #4,968 of 38,951
You are aware that the imod 5.5 needs an LOD with capacitors in, right?  If not your amp might explode!  (I don't actually know what happens when you don't use capacitors but am led to believe it's bad :ph34r: )  Using the capacitor LOD with the non-modded ipods will make them sound slightly worse...
Yeah I'm having it done by audio minor. He's putting blackgate nx caps inside of it. You can fit internal caps no problem if you have the thick back plate and a cf card mod
Jun 23, 2013 at 12:35 AM Post #4,969 of 38,951
I had two RWA imods a while back.
A 4th gen ipod photo and a 5.5gen imod with a 240gb hard drive (of course
size]
The 4th gen sounded better so I kept it.
My 4th gen has Backgate capacitors, and the LOD (ALO) I used with the 5.5 had (well some other caps that I forgot the name of{elna?}).
Anyhow, I think it greatly depends on what caps will be used with your imod...
EDIT:  NEVERMIND!^
size]
Jun 23, 2013 at 2:29 AM Post #4,973 of 38,951
funny now head-fi is giving free tuition to people on Permutations and Combinations - see Rudi's posts here :D
Jun 23, 2013 at 6:20 AM Post #4,975 of 38,951
Thank you for your help
My goal is only sharing for head fi friends here what kind combination from audio gear I can do ,and who know somebody can direct buy the best combo and save Money , not like me buy so many audio gear :D
Anyway thank you for your input
Hi Rudi0504,
Where did you order the MH335DW?
They are very hard to find.
I had ordered through our Indonesia Fit Ear Distributor Analog Head.
Thanks
Jun 23, 2013 at 6:47 AM Post #4,977 of 38,951
I have a pair of Wooduo 2 here with less than 60 hours them Jensy if you know anyone that wants a second pair. Case and tips included.
Speedy postage too. ;)
Jun 23, 2013 at 6:53 AM Post #4,978 of 38,951
Dat postage speed ;)
I just received these as a review pair. What's the etiquette here? I searched for existing reviews, and you have already done one - it's great, by the way!
Do I post my own review in your thread, start a new one, or do it on the product page?
Jun 23, 2013 at 6:57 AM Post #4,979 of 38,951
Arrh, I see. You create a review on the product page or create your own thread mate. Which ever you're comfortable with.
Jun 23, 2013 at 8:53 AM Post #4,980 of 38,951
Moi portable rig after selling the AK100 & Vorzuge Pure amp.
DX100 with UM Miracle on Toxic Silver Poison & Scorpion cables.
