- Apr 11, 2015
I am looking for the ultimate black.78mm 2pin to 3.5mm cable. (But not a thick cloth covered one) - durable plastic is fine. Any ideas?
Man that looks like a chunky monkey. Been thinking about upgrading my se100 sometime soon to either se200 or se180, but se180 looks a lot more chunky that the se100 or se200.
New A&K SE180, great vocal exp, musical & Mellow...
Edit, At last, welcoming to 4.4TRRS...
Yes.. a bit thicker then DX300, And quite heavier also..Man that looks like a chunky monkey. Been thinking about upgrading my se100 sometime soon to either se200 or se180, but se180 looks a lot more chunky that the se100 or se200.
Are you saying the se100 is on the brighter side of the se180?Yes.. a bit thicker then DX300, And quite heavier also..
soundwise, Futura sound will be bright compare to SE180 IMO.. dunno about SE200....
hmm, what I mean. by overall tonality wise, SE100 will felt brighter then SE180.Are you saying the se100 is on the brighter side of the se180?
Thanks. I love my se100. Main reason I wanted to upgrade was the led on the se200 and the cor change in the interface. I was looking at the se180 because the 4.4 I used to use on my fiio m11. When it gets time to upgrade I'd love to get my hands on both and compare to my se100.hmm, what I mean. by overall tonality wise, SE100 will felt brighter then SE180.
Soundstage wise, SE100 will be wider then SE180. S180 will felt more Midcentric.
What headphones are they?
Look like Kennerton Magni'sWhat headphones are they?
YepLook like Kennerton Magni's
