Pictures Of Your Portable Rig (part XV)
gaspir324
- Aug 2, 2011
MOAR BASS!!!!!!
With ZO on the max level I can feel it shaking my head and eyes. But I'm eagerly waiting for the ZO5 and XB10k.
You can never have enough (controlled, not-Beats-by-Dr-Dre) BASS!
Dreamnine
- Jun 17, 2009
SonicMaxPro BBE
It's not like BBE on a Cowon. There are 7 presets, and the various knobs offer the following (taken from the app guide):
Lo Contour - Restores detail and warmth to low frequencies
BBE Process - Restores clarity and definition to high frequencies
iSet - Adjusts center frequencies to find mid-range 'sweet spot'.
Sound Field - Expands the sonic depth and presence of your audio.
Mach3 Bass - Bumps low frequencies for more thump.
Mach3 Gain- Bumps the low gain for more punch.
The visual switch at the bottom just toggles between flat and the BBE settings.
I like it - previously I'd just been listening to the Touch on flat or sometimes its Rock setting; I've tried a bundle of music players with EQ options for ios and disliked them all, (at least none were better than the native music app imo). With this app the actual interface is quite nice and it's easy to import playlists, albums etc.
It sounds really good, at least to me. Worth the £2.99 I paid, definitely.
Ziilot
- Sep 23, 2011
Got new headphones, yay.
SoulSyde
- Mar 24, 2008
I approve!
elektrosteve
- Feb 22, 2010
SonicMaxPro BBE
Sounds very interesting. I tried the Cowon BBE last time and it was really good but only the normal BBE, didnt like all the other BBE versions. I also own a Touch 4G so I might try this app. I use the Hip Hop preset for my Phonak 112 with grey filters for now, sounds also really good.
shotgunshane
- Sep 25, 2010
SonicMaxPro BBE
Thanks for posting this. I haven't heard of it before. $4.99 in the USA.
Dreamnine
- Jun 17, 2009
The only setting I really don't like the sound of is the 'Sound Field' one.. it's just like the 3D stereo widening on Cowons.
The rest are really good (used judicially).
MorbidToaster
- Apr 23, 2010
Bought as soon as I heard BBE for my iPhone. $5 seems a bit steep but if it's good it'll be totally worth it. I'll post some impressions in a few.
EDIT: Totally worth $5.
Notice (as said before) Sound Field is off. That was the only one I didn't like too much. All of these settings are for the DJ100 straight out of my iPhone 4.
First off, don't worry about the presets at the top. That's all they are. You can start your own flat preset or just adjust one of theirs.
Lo Contour - This is a pretty fine bass adjust that does just what it said...Add warmth.
BBE Process - The best knob on there. It really makes everything sound more detailed and organic but can easily make it too bright.
iSet - This is a 'mids' adjust (that's what the app said anyway) and it's a weird knob for me. I found that right there is where it sounded best without 'bloating' (seems like the right word) the sound.
Mach3 Bass - I didn't use this setting much on my Cowon either. It's the finer bass adjust.
Mach3 Gain - This is the big boom maker. It can easily bloat your bass, but you'll notice huge bass 'kick' increases with this one when set properly. It's a little high at that screen shot, but it sure works.
As you can probably tell this is much like the other apps like EQu and what not where you have an entire music interface through that app itself. It functions very much like the others but seems like an overall smoother experience than my time with EQu. For one...I haven't had sound issue while multi-tasking here.
tl;dr - Spend $5. It's worth it.
My one complaint is that you can't select and artist or album before switching to it. If you pick artist of album it will immediately start playing the first song within that listing. A little nit pick.
LostMySelf
- Nov 15, 2011
Thanks guys, and what LOD do you use, something from Alo Audio?
MorbidToaster
- Apr 23, 2010
To be honest a lot of people use the L9.
LostMySelf
- Nov 15, 2011
I guess, it feels a bit cheap tho and not really the easiest cable to manage.
LouisLoh
- Feb 14, 2011
Or just JB. It's worth it.
Torontoraccoon
- Sep 7, 2011
yjt93
CAUTION: Incomplete trades.
- May 1, 2011
What JB ones are available?
when you jailbreak you can get all paid apps for free basically
Total: 8 (members: 0, guests: 8)
