spurxiii
- May 18, 2013
Hope the 3M Dual lock can help me get rid of the rubber bands
Vidmaven, does that mean the poster transplanted the BA and dynamic drivers from the Sony to the shells of the Shure then? hmmmm....interesting.
@amzies01 perhaps in order to decrease the obvious bass hump even more, you could get a pair of tri flanges/bi flanges but instead of inserting the iems deeply, insert them at the min possible distance to secure them in your ear. I find that when I increase the space between the driver and my ear drum eg using long tips that it does help to tame the bass a bit. Still the best bet atm is just get an equalizer app ( assuming u use yr phone as your source ) or to get an amp that has treble and bass toggles like the E17 if I'm not wrong. Wires are unpredictable and hard to demo unless you're in Singapore so it's best to avoid wires until you're sure they're what you want
Thanks for the suggestion bro. I think the Sony Hybrid mod is doing the job anyway... . I'm getting the FiiO cables for Shures on Sunday... They're available locally here in the Philippines... They don't cost that much either... Just an alternative to the stock Shure cables (which are pretty good already...)
Thanks for the tips though. Well appreciated.
That's why I didn't add "tips" anymore since...
1. It didn't occur to me that Sony Hybrids weren't only tips... And now it seems as if the "hybrids" you are pertaining to are the dynamic + BA driver combination IEMs ... - New information for me too. I know about the BAs but the hybrids are not available here in NZ.
2. It would be common sense that I'll be using the Hybrid tips to modify the sound to my preferences.... - That's what I originally assumed, but looking at your original photo, the tips look like some of the stock ones that come with the SE215, which caused the confusion. I have those as well.
