gimmeheadroom
Unusual to see such a large subwoofer used with headphones How are you enjoying the Megatron? looks awesome!
That's not a subwoofer, that's a woofer!
But, the bass can be a little wooly
Do you use cost no object cables, power cords etc. as well?
Funny, yes, but I'm genuinely curious. I used to question spending so much on cables in my own system until I listened...
A very polarising topic so I will tread carefully. My stance on cables for many years has been: as long as they (and the components) are of decent quality - the differences shouldn't be audible. Started by testing power cables. Ended-up building some high-end ones. Audible difference to me? Nope. A headache in terms of cable management and strain on the equipment sockets - yep. So the cables in my system are simple kettle leads on the DAC power bases and a flagship home made Furutech cable with matching Furutech connector powering the HE1 (simply because it looks nice and I built it - but sonically no proven benefit).Do you use cost no object cables, power cords etc. as well?
You are not far off....Would be funny if all the back was wired up with Amazon basics cable.
Please see a few posts above where I describe the cablingI’m interested now what’s it connected up with? Not everyone believes in high end cabling even with high end equipment.
I then moved on to power conditioners. I found some do make a difference - but I need to revisit this before being more specific.
Analogue Interconnects? This has been bugging me for a while. My system as originally pictured had Belden 1800F 1.5m XLRs which cost $61.50 from Blue Jeans. Best digital I have ever heard. Last week I purchased some expensive cables (to put to rest my doubts) - Nordost Valhalla II - XLRs ($10K+ retail but I got a decent discount from the Nordost dealer) - to go between the Select II and the HE1. This is the only analogue link in this rig and I would love to tell you that the Nordost's transformed the sound. Sadly, they didn't.
As much as I wanted to hear a benefit - I can hear absolutely no difference between the Valhalla II's and the Belden 1800F XLRs - either out of the box - or after about a week in the system. Given this system is probably one of the more detailed and transparent headphone rigs out there - if there was a difference to be heard - even a tiny one - am sure I would have heard it.
This of course is just one comparison (and opinion) - and I am sure other cables in other systems may indeed have a sonic impact - and maybe those with golden ears will discern a difference in my system - but I wasn't able to. YMMV etc.
My next upgrade will be the MSB Digital Director. Am hearing reports from owners that this is sonically significant and I will continue to prioritise the source components over cables budget-wise - and would really urge others to do the same.
Agreed - think the Valhallas will find it hard to justify their existence in the rig longterm.10k on ICs? Rather spend that on another flagship or two
I think there is maybe some merit to the difference between materials [I.E coper or silver (both at bottom dollar pricing)] - or at least in terms of utility - but yeah... 10k on ICs? Rather spend that on another flagship or two...
