Pico - USB DAC/Amplifier From HeadAmp
Sep 1, 2007 at 7:19 PM Post #61 of 711
Justin accepts preorders I believe, ETA given to me was October.
Sep 2, 2007 at 2:25 AM Post #62 of 711
Do you all think I should wait for the Pico instead of going for the Tomahawk? This amp sounds like the total package...DAC/amp combo and portability.
October is only a month away.
Sep 2, 2007 at 2:37 AM Post #63 of 711
If you're willing to wait, then yes I would.
Sep 2, 2007 at 3:06 AM Post #64 of 711
I think you are right sir. I'm going to email Justin to see if I can get on the pre-order list. I hope I'm making the right decision being that the Tomahawk is very proven while some members have only heard the beta...be it incredible.
Sep 2, 2007 at 3:13 AM Post #65 of 711
If you will be using your computer as a source, Pico will be much better than Tomahawk. However, you'll have to be patient. Justin is a perfectionist, he will not ship anything until it is absolutely perfect. Judging by what I heard at the meet, you will not be disappointed.
Sep 2, 2007 at 3:20 AM Post #66 of 711
I will probably never use it with my computer, just my iMod. Knowing that, do you still think I should wait or will it matter since I'm probably not going to use the DAC very often?
Sep 2, 2007 at 3:22 AM Post #67 of 711
If you will never use the DAC, purchase the amp only version.
Sep 2, 2007 at 3:24 AM Post #68 of 711
True enough, but if I'm going to spend $300, what's another $200 for an incredible DAC in case I decide to use it.
I will wait. I sent an email to Justin to see if we can pre-order now.
Thanks folks!
Sep 2, 2007 at 4:39 AM Post #69 of 711
Well boys and girls, MrJingles has just put himself on the pre-order list for 1 very special Pico DAC/Amp combo through Justin at Headamp.
Here is his email response:
"Joe,
Yes, I am taking pre-orders. No payment of any kind is necessary, just let me know if you'd like me to add you to the list and I'll contact you when they're close to being ready. I don't have a definite date. Right now I am getting the enclosures produced which is a 2-3 month process. Most likely it will be November.
Thanks,
Justin"
That, my audio friends, is what causes MrJingles to do The Happy Dance (imagine a mouse doing "Happy Feet").
Sep 2, 2007 at 6:00 AM Post #70 of 711
Do you think we will be able to pre-order and is he planning on manufacturing enough so there won't be a significant wait time like Xin or LaRocco?
While HeadAmp products do tend to have a built-in wait time, it's much more tolerable than Xin or LaRocco, shouldn't need to worry about that.
And HeadAmp is much more communicative than either of those two as well.
Sep 2, 2007 at 6:25 AM Post #71 of 711
Originally Posted by epaludo /img/forum/go_quote.gif
This USB power solution for the DAC part seems brilliant.
How much battery it'll need from the USB port?
Just wondering if it'll significantly decrese for example a laptop battery life. I don't think it must be significant though ...
Given that USB spec is usually a maximum of 500ma, and the Pico's USB audio device draws only a fraction of that, I'd guess it would be pretty negligible, depending on how much battery life your laptop has to begin with.
My Fujitsu P1610 can have up to 6 hours of battery life if I'm just listening to music, screen dimmed, and wireless turned off. About 5 hours with average use. Down to 4 hours with everything turned on, surfing wirelessly, with my phone leeching power and running as a modem.
-Ed
Sep 3, 2007 at 5:36 AM Post #72 of 711
I loved that little guy. How much HD space in there? Considering the batter and size of the Mini-DAC, the P1610+Pico seems like a better solution than iHP-120+DAC (unless there is another, smaller DAC than the Mini-DAC, which sounds better, has better battery life, and accepts optical; I doubt it.)
Sep 3, 2007 at 5:02 PM Post #73 of 711
I'm curious, what kind of battery are you using for your mini-DAC?
Sep 3, 2007 at 6:31 PM Post #74 of 711
Well, considering that the P1610 alone costs about $2000, it's a really expensive semi-portable solution compared to an H1x0 plus Pico (assuming one will eventually be made with optical out).
Sep 4, 2007 at 5:31 AM Post #75 of 711
I'm not, but I've seen it done with SLA batteries, and apparently there was also a portable DVD player battery from Ratshack that would do the trick.
Yeah, but I didn't say anything about value
. Considering that Ed already has the Fujitsu, I was thinking more of his particular situation than in general.
