Pico - USB DAC/Amplifier From HeadAmp
Aug 31, 2007 at 4:17 AM Post #16 of 711
if this thing does as advertised - small, drives all headphones, built in dac, great sound (this is the crucial factor) -, it's going to be a killer item.
Aug 31, 2007 at 5:36 AM Post #17 of 711
considering it out did a pro-dac on tests, it should be the best out there.
Upsampling design!
- Uses a flagship level 24-bit/192KHz digital-to-analog converter chip!
- Extremely low distortion analog filter
- Protects USB ports from over-current
- Extreme care in keeping noise to a minimum, separate power supplies for each stage
- 4-layer circuit board for optimum digital layout
- Separate analog input to use as headphone amp only
- Gain switch (toggle) on front panel
- Alps volume control w/ built-in power switch
- Lithium-polymer battery (estimated 35 hours, or 70 hours w/ extended battery option)
- Built-in battery charger w/ charge status LED on front panel (2-4 hour charge time depending on battery option)
- Back panel has the USB jack (Mini-B) and DC adapter jack
Aug 31, 2007 at 6:11 AM Post #18 of 711
Forget the Tomahawk reference, it looked like nearly the size of Xin's SuperMini. In other words, insanely small. And knowing HeadAmp, it'll probably come in a better chassis than the SuperMini. (Not a fan of the plastic case that Xin uses for it.)
Aug 31, 2007 at 6:38 AM Post #20 of 711
Justin mentioned that the cases will be like the ones used for the AE-2 (just smaller!).... IIRC. I got the impression that the cases are being specially made just to fit the Pico.
Aug 31, 2007 at 6:55 AM Post #22 of 711
sounds interesting.. esp. about that tiny side.
Aug 31, 2007 at 9:16 AM Post #26 of 711
well, this might replace my "poor man's microstack"...what's the ETA for this amp? i've been waiting forever for the new modules for the GS-1, too, but i guess justin's had other priorities...
Aug 31, 2007 at 11:04 AM Post #28 of 711
Don't quote me on this, but I have been told that this amp is able to add "tube" distortion like high end Headamp (without being tube) or Singlepower amps. It isn't a warm amp, like Xin's, but it should retain this ability.
Also, I've written to Justin about an optical line in:
Tony,
No, there is no optical input. To have an optical input, it would have
to be larger to add a SPDIF receiver. Also, when using the optical,
the
DAC would have to run completely on battery power. With a DAC like
this, that would drain the battery in only about 3 hours. So, while I
may make a larger version that also has an optical input (at least a
year away), it will need to be quite a bit larger to fit a larger
battery. I'm only interested in sound quality and not 200+ hour
battery
life, but I would still like the battery life to be at least 20 hours.
Thanks,
Justin
Aug 31, 2007 at 11:20 AM Post #29 of 711
I can't wait to buy this dac. When i went the boston meet nothing really excited me this much because once I hear the price tag I lower my head a walk away. But this little thing REALY excited me and made me smile even more once I heard the approximate price was 500. I mean I use my iMod 90% of the time. but when I am in my room and just want to listen to something out of some speakers or even my little Dot lll I always have to either drain my ipod battery by using that or I take it easy on my ipod and use the headphone out of my computer. Now my computer can be a source just as good as my iMod and ideally better due to it using a better dac chip in it. So I am super excited. SANTA!!! HELP!!
Aug 31, 2007 at 12:07 PM Post #30 of 711
Anybody heard or know about this poor man's Pico from Leckerton Audio. First time I heard about them and no results in search either, so I assume they are really new. Someone started a thread a few days back but no much interest there. I mean looking at the specs it is impressive compared to the similarly priced Total Bithead. Better casing, size, rechargeable batteries/circuit and DAC chips, I just hope the sound is on par.
Is someone getting first dibs and write impressions? Man it is just too sad, I am still too poor for a poor man's Pico
well at least for buying on the blind.
