FightBrothers
- Apr 19, 2012
Can you do a comparison between the Q701 and m50s to the X2 (if you've ever tried them) just as a reference?
I'll also be in a position to compare the X2 and the L2 in the next few days. I'll post my findings, as it seems there is a bit of demand for an understanding of the similarities/differences between the two.
Would anybody consider purchasing an O2+ODAC combo be overkill for the X2's? I need some help purchasing an AMP/DAC with this. Any help is appreciated!
It's not overkill at all. However, you might want to look at the Schiit Modi/Vali stack over the O2/ODAC combo. It should provide better performance, and the Vali gives you access to tubes for the low, low (relatively speaking) price of $120.
Thank you for the advice. I was under the impression that the O2+ODAC combo would be superior to the Modi/Vali for lower impedance headphones. I also have no experience with tube amps, would you still recommend me the Modi/Vali over the O2+ODAC? Thanks again.
Yeah, the tubes in the Vali are pretty small, soldered on, and non-replaceable, making it an easy recommendation as an entry-level tube amp for people new to tube amps. See here [taken from Schiit website]:
Anone know which I should get? HD650 or Fildelio x2? HD650 for $310 new, X2, $270 new?
Curious where you are finding 650 for $310 new?
Thanks
Sennehiser website, with code 35OFFSENN. It's 325 with 2 day shipping for me.
