Hammy
- Dec 13, 2014
Where can I check on the phones?
Pull the inner headband up, left side near the 'L'. It will say WOOX - we have yet to see one which says Gibson.
I was wrong. The text didn't look so yellowish anymore in the light.
Well no, the text is not 100% clear white, it has some subtle shade of goldish color.
"The metal ring with writing on it which holds the earcup is a different tone than the metal on the earcup itself on the WOOX version." Yeah, that's definitely true of my pair as can be seen in the picture.
And my pair is Gibson, and I'm happy with the quality of them. And quite happy with the sound too. I mean, imo they sound good "technically", but I get less "touched" by them emotionally than my good ol' M50's, in some songs I just prefer the closed and narrow centered soundstage of the M50's (that's just me). These beats M50 in comfort though, big time. They just at times don't have the same "soul" in the sound (lol), for me.
The funny thing was, the pair I got had WOOX written all over it on the box; cleary a "WOOX"-pair, while the one my friend got had Gibson all over it on the package.
They look absolutely identical design-wise, and they also sound absolutely identical. I have A-B'ed them for an hour now, and I'm in love with both (cause they're identical).
Just wanted to throw in my two cents after reading through a bunch of forums and threads and not finding what I was looking for, so I hope my input helps:
I have two Fidelio X2/27s and one Fidelio X1.
One X2 was bought on Amazon Warehouse Deals ("Like New, box is damaged" although the box was just a bit scratched up, no dents or rips and it was opened) and it is a Woox imported pair (underneath the box), and the one I bought New from the Christmas $200 sale is actually a Gibson imported pair as it says on the box. That one is still sealed in box until I figure out what I want to do with it. It's kind of a Schrodinger's cat and box situation. The AWD X2 was bought AFTER the Christmas $200 sale.
My Woox pair does say "Woox" on the headband. It also has NO GLUE on the pegs. HOWEVER the metal rings/trim/veneer around each cup have their silver edges peeking in a couple places that can be pushed down to make then flush, but they just go back to normal. they stick out fractions of an inch actually, but its still noticeable (if you know to look for it) since the edges are silver while the rest of the headphone is dark. The strip of leather(?) on the underside of the headband is also thrown on very sloppy, as it looks slightly too big and like it didn't fit quite right. It's in there pretty good, but you can tell it was glued on. The driver baffles are not depressed. There is no inking that I am aware of when I tried the printer paper test.
In comparison to the X1:
Headband: the strip on the X1 is expertly seated and seamless, and you couldn't even tell its a separate piece unless you look on the edge of the leather headband. Also I'd like to mention that the headband of the X2 is larger, and kind of.. pointy at the top. like the top of an egg, while the X1s have a more rounded look like the bottom of the same egg. Tyll mentioned that the X2 had a larger headband. The clamp is also stronger on the X1. (Does anyone have an X2 with a perfectly mounted leather strip? please pm me a picture if you do so I can compare)
Ear Pads: Same size. X2 is a darker, deeper black, and the pads are much softer, like they used a more gel-like memory foam A close look at the fabric shows it is the same kind of velour as the X1 and not the "felt" or velvet that a few complained about. They have the same thickness between X1 and X2. My X2s dont have one side a half a centimeter smaller inside one cup than the other like someone else mentioned. X2 is more comfortable than the X1. The suspension is the same on both models down to the coloring of the pleather and mesh (with the exception of the bolts that attach them to the band)
Frame: Some people have mentioned that the metal frame around each cup that the headband is mounted to is a thinner metal. My X2 frame has an identical thickness as my X1. The lettering I couldn't tell was whitish or yellowish, but I was looking at them under a yellowish light so I'm hesitant to say anything. I also didn't check to see if it was "fid elio" or not I'll do that when I get home.
Sound: The most important part of all: At first they sounded almost exactly the same as the X1, except the mid-range is a BIT more forward on the X2, and the Treble is more forward on the X2, which makes the X2 a clear upgrade over the X1. I thought the X1 was pretty unifying and dynamic until I listened to the X2. X2 is a bit more dynamic and just sounds a bit more "complete" like it filled in the gaps that the X1 had. The bass is also SLIGHTLY better. Mid bass sounds exactly the same. Bleed into the mid-range is almost the same but I cant be certain until I give it another go. (TH-X00 keeps seducing me away) Sub-bass is a tiny bit more present on the X2, which makes the mid bass hump of the X1 seem a bit more in line and balanced on the X2. X2 is SLIGHTLY more detailed, Soundstage is confusing because the recessed mids on the X1 make it seem like there is a more 3D feel with the depth in front of you like the singer is standing in front of you, as opposed to the singer being a little bit more in your face on the X2. The treble on the X1 was a bit recessed compared to the X2, but it made everything feel a bit more airy and magical. The X2's slightly more forward treble seemed a bit more detailed, a bit more shimmery, but less airy and magical. All in all I felt like these were very tiny differences between the two headphones and I was kind of regretting buying both, so to justify my purchase I read a couple more reviews including Tyll's review of the X2 and found that his impressions were essentially the same as mine. The differences I heard between the two were exactly what was showing up when I compared the X1 and X2 graphs on inner fidelity. The only thing I did not hear was the "graininess" that Tyll mentioned. Other members in other threads mention the X2s being warmer and darker sounding than the X1s and I completely disagree. The X2s are an slight upgrade of the X1s, with an extremely similar and a bit more complete and comprehensive sound. Like a version 1.5. The X2s are better, but only just, at least with the pair that I have, especially since I bought the X2s for cheaper than I got the X1s :3
Note: Tests were done on a Sound Blaster E5 simultaneously (two headphone outs, two Vmoda Cables)
I hope this helps some of you guys out in figuring if you have a "bad" set or not. Happy listening.
This is making me think that it's not really about the WOOX / Gibson branding but maybe overall bad quality control.
