madwolfa
Ugh... See this is what I'm talking about....
Now what should I do....![]()
With Amazon's return policy it's a no brainer to buy it and try it by yourself, IMO.
What's your budget? From what source will be using? Do you have, or plan on purchasing an amp? Do you require isolation - for you not to hear sound while you play, or for others to hear sound leaking?
It's not too late to cancel the whole order.
For sure, but even if I like them, what if there's better :O?
WHAT IF I'M MISSING OUT?
What if... THE CAKE IS A LIE?
I guess I shoudl order them and find out though... Still a hard decision, and I wish I had another pair to compare to...
Didnt' place it yet...
I actually realize I might not have enough for all the crap I want....
I thought I had more money than I do... ugh...
How long does it take Amazon to bill people? I have a check I need to bring to the bank tomorrow...
Chill out, bro.![]()
You need to find out what you're looking for before you purchase anything.
You need to find out the type of sound you enjoy. You may have to try several headphones before you decide what you want.
Good luck!
I've been lookign for awhile, and wasn't thinking about getting anything, but now with this deal it seems too good to pass up... I almost bought them awhile ago, because they sounded what I might be lookign for, but everyone has their own opinions... It's hard to know what's what...(((
Gave it a quick listen and this type of music to me sounds better on my HE 560 then on X2 (but most things do) IMO this music will play better on planar headphones.
That's why you have to decide by yourself. This is a very good deal in any case.
Saying the HE-560s are better, while no doubt true, is not particularly helpful here. Today, they're almost $500 more expensive than the X2s.
No one will doubt the HE-560s are top-notch but at $400-500 more, they're expected to be.
Rather, the X2s should be compared to the Hifiman 400s or Sennheiser HD600, or AKG K7XX/K712, all in the $200-$400 range. Those are its competitors, not $700 headphones.
I'm just scared that I'll run into an issue like the HRM-7's that not only weren't what I want, but were way too harsh.
With the exception of the HE-400S, which is $300 MSRP, all planar headphones are more expensive than your budget of $300 (as noted in the thread you linked to). The next cheapest planar, the Oppo PM-3, is $400. The HE-560 is even more than that. Since you were saying you don't have a ton of money, it seems to make sense to maximize your dollar, which this sale does. On the other hand, if you really don't have enough, maybe this isn't the right time to go further with this hobby.
On the other hand, realize that you don't necessarily need everything at once. Maybe you could get some less expensive, easier to drive headphones for now, then get a good amp, then upgrade your headphones later, then get a DAC to really bring out the best in your files.
Also, realize that there are no perfect headphones. If there were, we'd all buy those and no one would make anything else. These headphones may or may not work for you, you won't know until you try them. But at this price, it's a good deal.
Eurobeat, buy some great and versatile headphones like the X2. Life is an existential dilemma where choices close off or alter other choices. Get over it. Buy them and forget about fringe concerns like balanced cables. Enjoy the dang headphones.
S.O.G.O.T.P.
I listened to a few songs that you linked. That Eurobeat music is intense lol!
I tried them on my nicely modded planar T50RP's, on the MT220's (with Brainwavz hybrid memory foam pads that reduces the brightness quite a bit) and on the X1's. I kind of depends on what kind of bass you want. If you want hard hitting fast bass, then some planar magnetic hp's might be the way to go. I personally like bass that isn't quite so hard hitting (especially with music like that), so I enjoyed those songs more with the mt220's and x1.
Personally, I'd just get the X2's for a good price somewhere that you can return them. They will be awesome all rounders and my guess is that you won't want to return them (but if you do, then you can).
Btw, the mt220's with the hybrid pads sound amazing imo (but I'm not necessarily saying they sound better than the X2's which I've never tried).
So you like the sound with the Yamahas...? I was thinking of ordering them with these, and returning one, but not too sure if I could return the Yamahas, and don't want to be stuck with them :'(....
