I think Fidelio X3 release is more likely, lol. This time with smooth highs.
You must be really sensitive to harsh highs to have a problem with the treble on the X2's IMHO .
I don't have a problem with it, not really. But that doesn't mean it couldn't be smoother. Try listening to "I Turn to You (Hex Hector Radio Mix)", you'll hear what I mean. It's not harsh, no, but not very smooth either. Grainy might be the right word. Grain-free X2s would be the perfect headphones.
I personally don't like when the highs get too smooth but as always YMMV....
Edit :I'm also not a person to look around for music that may or may not sound bad on my headphones /IEM's . As long as it sounds good with the music I like I'm happy . I'd guess I'm just easy to please
I have had a pair of Fidelios X2 for two days now. I first heard X2 a couple of months ago and liked the sound. During the last two days I critically listened to these headphones and compared them directly to my HD600 (which is my kind of reference). I am pleased with some aspects of the X2 sound but there are some things that bother me. First, I think that bass gets overpowering on some music bloating the lower mids and making negative impact on vocals. Second, the treble is a bit grainy. The more I listen and compare to HD600 the more I feel like the treble of X2 is kind of artificial. Anyone else who has similar experience?
I love Fidelio X2, really. I'm just sensitive to treble as you said. Also I Turn to You is one my favourite dance tracks so I listen to it a lot.
I do not experience the 2 negatives that you mentioned. I also have HD600, and I prefer X2, for it has better extension on both ends with better sound stage and the sound is very natural and musical. Probably, the sound is also affected by other factors, e.g. DAC (Anediol D2), HP Amp (Gustard H10), and genre of music played (Mainly Classical Music). I also like my HD600.
What amp are you using?
Not sure what that song is supposed to sound like. But it sounds great. Tidal>Element>X2
Is it just me or do they sound better if you have them far forward on your ears?
I use my Marantz SA-KI Pearl Lite CD player and Matrix M-Stage headphone amplifier with Fidelio X2. I listen mainly to jazz and classical with X2.
X2 sounds darker than HD600 and while it has more bass and also more defined bass I feel that the bass on X2 influences the rest of the frequency spectrum (and colors it) in quite an unnatural way.
The treble is less defined on X2 which makes some instruments sound artificial. Brush on a snare drum sounds more life-like and true through HD600. Cymbals sound also mole true to life with HD600. A single violin (Bach solo suites), and violin sections in an orchestra tend to get a synthetic sound on X2.
I had huge expectations on X2 after reading so many positive reviews. Maybe something is wrong with the pair I have?
The Matrix M-Stage has an output impedance of 5 Ohms which might be a bit too high for the X2s, it should be at least 8 times lower than the headphone impedance (See "damping factor"). If the damping factor is too low you might get an additionally boosted and somewhat bloated bass. The Fidelio X1 and X2 are sensitive to this.
Yes, be sure to try another amp. I heard a vast improvement after switching from 10ohm to 0.1ohm.
