AltCtrl
- Sep 7, 2011
I'll be getting a X2 for Christmas.. coming from a DT880. Pretty excited.
Not sure how much the X2 will benefit from an amp with it being 35ohms. I have a asus essence STX which has an amp in it and a matrix-m-stage. I'll try them both and see what the difference is.
Make sure the output impedance of Essense STX to be lower than 3 ohms. High output impedance amps with low impedance headphones can cause subpar sound quality.
I read the matrix-m-stage has output impedance of 5ohms.
Essence STX has 10ohm output impedance but optimized for 32-600ohm headphones. Does that make sense? Can you control the output impedance? I haven't played with it.
"Optimizing" makes zero sense. 10 ohms for 32ohms is never optimized, period. Will the X2 (or any other 32ohm headsphones) be driven on the STX? Yes. Even 16ohm IEMs or cheapo $5 headphones can. But that's not "optimized".
Bitten the bullet :atsmile: .. Ordered in amazon and it is arriving tomorrow.. Hopefully it complements my P7.
Excuse my ignorance but I don't understand how my matrix-m-stage has a 5ohm output impedance and the STX has a 10 ohm output impedance when the m stage is a much more powerful amp.
Waiting for your impression and comparison with the P7.
Thank you for your impressions. Very helpful! It seems the P7 can switch gear and scale up better than the X2 with proper amping. However, the X2 is the slightly better all-rounder as i can understand from your impressions.
which one is warmer?
and one last questions, which one would you be able to turn the volume higher while still sounding pleasant and not harsh?
thank you very much!
