Koval
Member of the Trade: Perun Electrostatic Headphones
From myself, I can say: in the Rock version there are simply more low frequencies ... and that's it.Still no impressions of the Rock version (and comparison to PLS)?
Any disadvantages?From myself, I can say: in the Rock version there are simply more low frequencies ... and that's it.
Thanks. I appreciate your feedback.From myself, I can say: in the Rock version there are simply more low frequencies ... and that's it.
Yeah - I am also curious. I am a little of a basshead, and mostly listen to rock and metal music, so I thought Rock version would be a better fit for me.Any disadvantages?
Are they heavier due to the bigger size and two way construction?
Do they have dust covers? How much do you have to take care of them?
Haha - sounds like you got MY Peruns... I have ordered the PLS with upgrade cable in red, too.Hi guys I'm a stax noob who recently impulse bought a pair of PLS with upgraded cable and this is what I think about them so far:
As a disclaimer, I don't have golden ears, and I'm not much if a writer so bear with me.
Right out of the box, they look just as great as they do the in the photos.I got the red color which I think makes the PLS way more luxurious and the wood quality definitely lives up to expectations.
In terms of comfort, they're very comfortable. If I had to nit-pick I'd say the headband likes to stay flat on my head so it can hurt the very top of after about 2 hours, but with some padding I managed to fix it. Honestly, it might just be me.
Probably my favorite part about the PLS is how easy they are to drive. I have a 323s and 727a and both drive the PLS so well I don't feel an upgrade to a KG amp would benefit me at all.
Regarding sound, all I'm gonna say is that they blow anything e-stat I've owned out of the park. (nectar sound pollinator, sr-003, and a esp-950). The pollinator is honestly about the same bass quantity but i prefer the improved resolution of the bass on the PLS. The sound staging is wider than the above 3, and so is the dynamic range.
thanks guys. sorry for the crap post
What's their sound signature like? Is there anything they do particularly well or poorly? Pics?Regarding sound, all I'm gonna say is that they blow anything e-stat I've owned out of the park. (nectar sound pollinator, sr-003, and a esp-950)
Did you get your Peruns yet?November
Looks like two bookshelves is the new
I wish he made it bigger DDD
Look way bigger than I thought...Looks like two bookshelves is the new
