Antony6555
- Aug 26, 2007
Quote:Hm. What paper do you use? i use black and reds and rhodia pads (as per someone here's recommendation). I have one of th elittle pilot mini's so i can give that a shot. but im not really looking to drop a another $20-$40 just on a maybe
Lamy's are notorious for having nibs that don't match their stated specs, return it and try another EF, some of them are in reality mediums, while you may run into an actual EF. It's pretty much by chance.
Hmm, I haven't heard that exactly. What I have heard is that Pelikan and Lamy nibs tend to be larger than most other Western companies nibs (there's no standard for nibs and all companies tend to vary at least slightly). Actually, it's something they recently began doing I believe, perhaps to differentiate fp from bp more?
@erratik
Hmm well your paper's fine. I suspect that the lamy is simply too broad for your taste, I doubt anything is wrong with it. It writes like a broad gel pen correct? If you want, you could try exchanging it anyway though. If you want a pen that writes like a fine (or x-fine) gel pen, you'll probably have to go with an asian brand. Check out fountainpennetwork.com if you want you're interested.
