does the type of ink you use have an effect on thickness? I have what *SHOULD* be an extra fine lamy safari vista with lamy ink and it is not at all what i would consider an extra fine write. probably somewhere closer to bold. it also feathers. a lot. at this point it was basically a waste of $40 =/
It's probably the paper you're using. Even if it seems like "quality", it doesn't mean it was designed to be used with fps. Most paper these days isn't The ink could be a contributing factor as well, but even bad ink shouldn't that strong of an effect? There's plenty of cheap paper that works well with fps out there, you just have to experiment a little. Still, your safari may never write like an extra-fine gel pens, if that's what you want. Lamy is known to make nibs on the broader side of the spectrum. If you want a fp that really writes like an extra-fine gel pen, you might want to try an extra-fine Parker instead. Alternately, you could pick up a pen from an Asian brand (read: Japanese). Asian fp nibs run smaller than Western one's (because of their intricate writing system). Look at Pilot's line if you're interested. Even an Asian fine nib should be equivalent to an extra-fine gel pen (at least mine is).
